Apexi Midpipe
Subscribe
Apr 3, 2018 | 03:33 PM
Hoping someone can help here as I'm looking to install the Apexi Midpipe (product link).
I'd like to know if there is a catalytic converter in exhaust part 17420 (exhaust diagram here). I'm looking to replace this with the Apexi Midpipe but do not want to increase pollution into the environment.
Thanks in advance!
Reply 0
Apr 11, 2018 | 05:49 PM
Lexus Service confirmed that there's no cat in the OEM midpipe/resonator. Here's what it sounds like.
Reply 0
Apr 14, 2018 | 01:17 PM
You have two cats, neither are in that length of pipe.
I'm hoping that is some kind of audio compression issue or something but from the video your NX has a fast "put-put" train like sound at idle. Was that recorded straight from the phone mic? They often have built in noise cancelling properties. Also am I hearing pops? That's cool, my GFs cooper S does that.
I know the section you replaced is the main muffling part of the system. I have pulled the back two mufflers before and there was very little sound change.
Reply 0
Apr 16, 2018 | 01:23 PM
Thank you for the cat information.
The YouTube video actually isn't my car but I do like the sound of the car, even though the mic seems distorted during the recording. I just purchased the Apexi Midpipe and will record some videos to share how it sounds inside and outside the cabin. Stay tuned!
Reply 0
May 10, 2018 | 09:24 AM
Finally got around to installing this and I think this is one of the best <$500 upgrades you can make to this car. It took me just under an hour start to finish and the car sounds really great, although it's a bit tough to hear inside the cabin due to how well sound insulated it is. There's a noticeable power gain as the Apexi midpipe is a straight pipe that removes a huge stock resonator, lowering back pressure for the turbo. One of my main concerns of removing a resonator was the introduction of drone but as mentioned before, the cabin is so well insulated that you don't hear anything unless you're hitting the higher RPMs. Check out some of my recordings below!
Shout out to Meraki Autoworks (https://www.merakiautoworks.com/) who was able to hook it up in the LA area.
Reply 0
May 14, 2018 | 11:14 AM
Thanks!!
-Josh
Reply 0
Aug 9, 2019 | 09:39 PM
yuck, not to **** on anyone's parade but these engines don't sound good at all. The exhaust note is horrid, like an anemic thing that is dying . Now it just sounds like a riced out honda to me. I'm still annoyed Toyota didn't put a 6 cylinder in this vehicle...
-Nigel
Reply 2
Aug 9, 2019 | 09:41 PM
Rice was the goal.
Reply 0
Aug 10, 2019 | 09:03 PM
Quote: Rice was the goal.
No offense but that not my fav exhaust note. There is actually another mid pipe only option with open/close valve option from zees project: https://m.youtube.com/watch?v=E-KFaY...ature=youtu.be
Reply 0
Aug 11, 2019 | 05:55 AM
I actually had an appointment with an exhaust place next week. I have since canceled the appt. Thinking that these 4 cylinder engines can sound anywhere close to good is a joke. No matter what we do, these small 4 bangers will never sound like we hope. We are just throwing money down a deep dark hole. Not worth it in my opinion. to those that have it and like it, congrats. I know to each their own but it just aint for me.
Reply 0
Aug 11, 2019 | 05:04 PM
Quote: I actually had an appointment with an exhaust place next week. I have since canceled the appt. Thinking that these 4 cylinder engines can sound anywhere close to good is a joke. No matter what we do, these small 4 bangers will never sound like we hope. We are just throwing money down a deep dark hole. Not worth it in my opinion. to those that have it and like it, congrats. I know to each their own but it just aint for me.
I was thinking g Apexi but after I heard a couple, I changed my mind. I think the zees project mid pipe with open/close valve option is the only one I’d consider but the shipping cost is outrageous...
Reply 0
Aug 11, 2019 | 06:58 PM
the Zees sounds ok just running and give it a little gas. But put it under a load and I bet it sounds ricey too. To pay any amount of money for exhaust on these cars is just really for looks. I was going to have my guy create something one off for me, like he has done in the past. But I can't bring myself to do it. Kudos to those who want this sound but its not for me.
Reply 1
Aug 20, 2019 | 11:07 AM
I think another thing that kills the engine note is the variable Atkinson cycle via valve delay. It is very noticeable at idle and sounds "put-put"ish.
I have tried a lot of exhaust changes with little good sounds. The axle-back part will change the sound quality ZERO amounts. Don't waste your money unless you're chasing weight loss. The mid-pipe section does most of the muffling work. If you replace it with just a pipe, you get a very loud and annoying car. You can buy multiple different brand name mid-pipes but they all allow the "put-put" sound to appear. This is mostly at idle, which I would like to be quiet anyways. So, I have also tried an electronically controlled dump valve. This allowed me to be loud only when I wanted but sounded terrible at half-open with a metal on metal vibrating sound. The valve opened slowly so you heard the vibration for a while (10+ seconds). My most recent exhaust mod is a boost controlled dump valve. It makes the car VERY loud because (for me) it dumps right after the first cat (which I don't have). The valve opens quickly so no vibration noises and has a constant spring dampening it. The valve was designed to open at 5psi but that is way too soon. So I have been tuning the number. 12psi has seemed nice. It stays open at full throttle but almost no other time. I think my next add on will be a mini resonator style muffler from Jones attached to the valve.
Reply 0
Subscribe
