Air filter - one or two?
Another noob question. I read user manual, no word found on it.
Does 200t have 1 or 2 air filters? I already had OEM one out, for inspection, the big guy, and have high air flow on order, as replacement. But, at a glance, in air ducting, there's a piece that looks like a housing for cylindrical filter and, just at a glance, it appears to be part of turbo air supply. Sort of off engine center to the right, facing it, in front of the plastic engine cover. Like a bulge in air duct with clamps on each end.
Took a good look at that "canister" I asked about. I don't believe it's a filter housing. Didn't really wanted to mess with several screws to take it apart and see what's inside. Eventually.
If you are speaking about this Canister shaped piece (circled), It is a silencer for the turbo. I can not tell you much about it since it is not a serviceable part. What I can tell you is that, it is not serviceable so there is no filter inside it, no charcoal... nothing like that. More than likely it is something like a muffler in design. It lessens the whistle and BOV sounds made by the turbo under heavy acceleration.
