2018 NX homelink won't pair
hey guys, I just got my 2018 NX today. I'm trying to pair homelink with a Craftsman opener, dated 1999 I think, with a red learn button and a white wire by every possible button combination possible. My previous IS worked fine. I've cleared the homelink, tried the transmitter way (universal "Clicker") and the learn method. Nothing. Could someone perhaps share with me what I could be doing wrong or what I need to do? I followed the instructions to the t in the manual, watched the vids on homelink website, nothing.
Thanks HS for the help |
I assume the process for getting one of the homelink buttons to learn the Craftsman remote looked to work fine? If so, when you try to get the opener to learn the homelink button, try doing a longer press of the homelink button. I've had that issue before (not the NX) where a quick button press wouldn't activate the opened. But a long press would.
No, the homelink didn't even learn the code yet. I have a Chamberlain universal clicker and I've held the damn button for the full duration that the orange light was blinking to no avail. I pressed the homelink button once and it flashed orange the whole time. Held down the remote at the mirror and nothing.
Tried the learn button method and no success. I'm stumped. New battery in the remote too |
Quote:
I have had same problem with my 2018 NX and a Chamberlain clicker - tried every way possible without any luck. Spoke to my dealer they are trying to get their tech guy to come out to my home to help me out.
don't know if this will help you specifically, but have you looked into getting the homelink bridge/repeater? It allows the original rolling code signal to be boosted and make it easier for the homelink in your car to read it and program
other thing, can you borrow another clicker that happens to be compatible with your opener then see if the homelink can learn that one? Then you have the opener pair with the homelink.
Quote:
But the rep was adamant that the homelink button had to be held down simultaneously with the opener and not simply pushed and released as the car manual states. It's driving me nuts. |
The homelink web site specifically states that the homelink button had to be held down simultaneously with the opener - I tried that - but it did not work.
Quote:
While the original 1999 Craftsman remote would have transmitted continuously when
the button is pressed the newer Chamberlain may just emit a short blast to save the battery. Try training the car again but cycle the remote button repeatedly and see if you can "accumulate" enough signal to set the code. Additional clarification is need regarding the NX's HomeLink procedure. Our older Lexi had a single red light that flashed 1) slowly if the channel was clear, 2) quickly if there was a rolling code successfully trained and 3) solid if an old non-rolling code was in there. This generation of HL required the car button to be pressed throughout the transfer process. The OP's NX (and other new Lexi) have a 1) orange light when the coast is clear and 2) blinking green when a code is present. These now only respond to a single touch that starts the 30 second window and shows the orange light. When it changes to flashing green you are ready for climbing the ladder to press the "Learn" button. Let's not get started on how many colors, shapes, locations and types of screws and flimsy clips it takes to get to those gems... |
Quote:
Exactly right, good luck.
Thanks - tried it and it worked - took a long time though.
Ok, so I got it to work, but the manual's way. Cleared the codes, pressed the button once, and then used a second remote with a fresh battery (same situation with the first one) and held the remotes button to the HL, and voila! It worked.
| All times are GMT -7. The time now is 11:59 AM. |
