Lexus NX USB ports
Hello! I see in my 2016 there are two USB ports. Is there any difference between them? It supports to play video from USB Flash Drive? In my 2013 Lexus ES300h the max accepted usb flash drive was 32gb. Does Lexus NX support USB flash drives that have more then 32GB? What format system i should use? Fat32, ntfs or exFat? Thank you in advance!
While Windows will limit you to 32GB when formatting with FAT32, you can use third-party programs to still format a FAT32 partition that is beyond 32GB. In the LS thread below, post #24, the poster confirms he formatted a 64GB USB stick as FAT32 and it worked fine for the LS 460, which I imagine should work for the NX as well.
https://www.clublexus.com/forums/ls-...ml#post9919552
