ClubLexus - Lexus Forum Discussion (https://www.clublexus.com/forums/)
-   NX - 1st Gen (2015-2021) (https://www.clublexus.com/forums/nx-1st-gen-2015-2021-264/)
-   -   low rpms - transmission's memory reset would help? (https://www.clublexus.com/forums/nx-1st-gen-2015-2021/1027942-low-rpms-transmissions-memory-reset-would-help.html)
TomekR Aug 26, 2024 02:11 AM
Hi,
One of the annoying things in my NX300 is that while driving at constant speed apr. 50-60 km/h engine RPMs goes too low, (below 1200, to 1100) and I can feel unpleasant vibration on the car.
My guess is also, that it's not healthy for the powertrain.
It doesn't help if I switch the mode to sport.
As I bought it as used car, maybe this is result of transmission's adaptation to previous owner's driving style?
Therefore I wander does the transmission's memory reset would help here ? Haven't checked is this option available in Techstream though, but I've seen some posts on LS's forum about it.
MartyMarty Dec 12, 2025 03:36 AM
Hey, did you ever solve this? Mine has same issue. Even in neutral as I rev from 800 thru to 1500. Rough around 1100
bazzle01 Dec 15, 2025 04:21 PM
Try removing Neg battery terminal for 30mins.
Sometimes helps reset drive modes back to standard.
Then drive it how you want so it learns your driving style.
