Morel Ultimo 10, Soundstream PCX2000D, BNIB Focal Utopia 6.5" Mids
Morel Ultimo 10 $380 shipped (cont. us) including paypal fees
used for 6 months; like new; amazing sq and spl; dont have original box or manual; selling sub only
specs:
# Overall dimensions DxH 263mm (10.53) X 140.3mm (5.52)
# Power handling RMS P 1000 W
# Transient power 10ms 3000 W
# Sensitivity 2.83 Vrms / 1M 87.5 dB
# Sensitivity 1W / 1M 84.5 dB
# Frequency response 10-900 Hz
# Cone material Carbon-fiber laminated paper
# Net weight 6.5 Kg. (14.3 lb.)
# Driver Displacement 2.34 Lit (0.08 cu.ft)
# Voice Coil Diameter 130 mm (5.1)
# Voice coil height 37mm (1.45)
# Voice coil former Aluminum
# Voice coil wire Hexatech Aluminum
# Number of layers 2
# Max. Linear excursion X 12.5mm (0.5) (Each way)
# Magnet system type Double magnet vented
# HE-Magnetic gap height HE 12mm (0.5)
# B flux density B 6.4 T
# BL product BXL 13.0 T.M
# Nominal Impedance Z 4.0 Ohm
# DC Resistance RE 3.7 Ohm
# Voice coil inductance @1KHz LBM 1.0 MH
# Suspension compliance CMS 0.22
# Mechanical Q Factor QMS 1.71
# Electrical Q Factor QES 0.55
# Total Q Factor QTS 0.42
# Mechanical resistance RMS 13.9
# Moving mass MMS 128 gr.
# Eq. Cas air load (liters) VAS 34.5 Lit (1.22 cu.ft)
# Resonant frequency FS 29 Hz
# Effective piston area SD 0.03 m
Soundstream PCX2000D $280 shipped (cont. us)including paypal fees
used for 6 months; new condition; comes with original box, manuals, end caps, etc.
specs:
# RMS Power Ratings:
* 1100 Watts x 1 Channel @ 4 Ohms
* 1500 Watts x 1 Channel @ 2 Ohms
* 2000 Watts x 1 Channel @ 1 Ohm
* 4000 watts max approx.
# TST (Twin Stack Technology): Allows 2 Amps to Drive One Voice Coil!
# High Quality FR-4 Circuit Board
# Class D Circuitry
# Continuously Variable Low-Pass Crossover: 50 - 150 Hz (24 dB/Oct.)
# Continuously Variable Subsonic Filter: 15 - 40 Hz (24 dB/Oct.)
# THD @ Rated RMS Power 0.5%
# Signal-to-Noise Ratio 80 dB
# Variable Subwoofer Equalizer: 0 - 18 dB
# Phase Control: 0° / 180°
# Frequency Response: 5 - 250 Hz
# Adjustable Input Sensitivity: 0.5 - 4V
# Damping Factor: >200
# Fully Regulated MOSFET Power Supply
# PWM Circuitry
# Platinum Power and Ground Connectors
# Accepts up to 16VDC Power Input
# Wire Bass Remote Included
# Dimensions: 10"(W)x2.5"(H)x22.2"(L)
Focal 6w4255 6.5" Mids SOLD
Kenwood DDX-7015 6.5" Screen $360 shipped
I've had this for a few years and it works like a champ. No scratches on the screen. Comes with remote. Plays everything - mp3 discs (both cdr and dvdr), cds, dvds, burned dvds, 18 fm presets, 6 am presets, etc etc. This screen works perfectly.
Focal Utopia 5WS 5" Subwoofers (Pair) $250 shipped
These are very sought after. I have no room for them in my kick panels, so they have to go. Near mint - only some surface scratches on the magnets.
Special long excursion subwoofer.
136mm subwoofer for small bass reflex enclosure.
40mm voice coil, 100mm magnet
Impedance: 4 Ohms
Max. power handling: 160W
Nominal, power handling: 80W
Sensitivity (2.8 V/1m): 87dB
Frequency response: 45Hz*-2.5kHz *Depends on load
Mounting Depth 74mm
Diamond Audio D7401 Reference Amplifier $375 shipped
This is top of the line Diamond Audio! Not only that, but the D7 series is considered to be one of the finest series of reference quality amps. Absolutely Brand New! Its seen power for testing purposes, but has never been used in a car or mounted to anything. Amp comes with birth sheet, original box, manual, and original packaging. The side panels are detached in the picture because i was cleaning some dust out since the amp had been sitting for a while. It will have all the panels attached and will work and look as new! The reference # is a d7152 number because they are the exact same amp, except the d7401 is wired for mono internally.
400 Watts x 1 @ 4 Ohms (Birth Sheet shows 425wrms @ 4ohm)
800 Watts x 1 @ 2 Ohms
Frequency Response: 3-50,000 Hz
Signal-to-Noise Ratio: 102dB
THD: 0.02%
Length: 19 1/2"
Width: 10 5/8"
Height: 3"
specs:
specs:
# Class D Circuitry
# PWM Circuitry
Impedance: 4 Ohms
Mounting Depth 74mm
THD: 0.02%
Length: 19 1/2"
Width: 10 5/8"
Height: 3"
brendanlim
03-05-05 07:37 AM
Ag02M5
08-09-02 09:36 AM
