CarPC, Complete plugNplay Kit w\7" Indash Enclosure
#32
Its a PPI Amp 5440 5-channel,
Specs are:
Power Rating 4Ω 30 W x 4 + 120 W
Power Rating 2Ω 60 W x 4 + 200W
Power Bridged 4Ω 120 W x 2 + 120W
Power Bandwidth 70Hz~80Hz
THD 0.05%
S/N Ratio >105dB
Input Sensitivity 100mV~12V
Input Impedance 10K Ω
Load Impedance(Stereo) 2Ω~8Ω
Load Impedance(Bridge) 4Ω~8Ω
Supply Voltage 10V ~15V
Damping Factor > 300
Slew Rate > 45V/µS
QBassTM Equalization Up To 12dB Boost@40Hz
Dimension (WxDxH) 435 x 256 x 62mm
Other noteable features:
4/5-Way Variable Crossover with RCA outputs
QBassTM Bass Boost
Balance Differential Input Circuit
Speaker lead high level input
High Voltage Input capability
Gold Plated RCA, Speaker & Power Connectors
Mixed Mono /Stereo Operation
The AMP alone goes for $200,
Specs are:
THD 0.05%
S/N Ratio >105dB
Slew Rate > 45V/µS
QBassTM Bass Boost
3rdelement
08-09-05 10:12 AM
