Knock sensor/s R&R
Old Sep 24, 2021 | 09:56 AM
Helicopter's Avatar
Helicopter
Default Knock sensor/s R&R
2000 Lexus ES300 V6
Hi Folks;
The old Lexus will not go into O/D after the engine warms up.
Consensus is that it may be the Knock sensor/s.
Correct me if I am wrong but is it (or they) beneath the intake manifold?
Also, is it one or two?
Some people caution that non-genuine Lexus knock sensors are problematic.
any advice?
Roy
Old Sep 24, 2021 | 11:09 AM
First verify the sensors are bad, if they are you will certainly have knock sensor code(s). Do you have a code reader? There are 2 under the intake, you 100% must use only genuine parts unless you like doing the job twice.
Old Sep 24, 2021 | 08:43 PM
Helicopter's Avatar
Helicopter
One other chap on youtube had to R&R the "speed sensor" to get the O/D problem sorted out. I am thinking that perhaps I should replace that also.
Old Oct 4, 2021 | 07:23 PM
Helicopter's Avatar
Helicopter
I R&R-ed the knock sensors and it appears to be going into o/d (I don't want to jinx it be saying it is working).
I found a lot of "clips and snaps" electrical connections with an assortment of ways to un-clips them. Some were like a Chinese puzzle box. Also the plastic under the bonnet is very brittle due to age and heat. Fitting this problem has been uphill from word one.
LexusOwn15
Apr 10, 2021 02:27 AM
DREED2017
Jun 21, 2017 01:43 PM
Max9911
28
May 12, 2015 08:49 PM
Lexus1996
Jan 4, 2008 11:05 PM
yoji6365
Maintenance
Mar 27, 2005 03:25 PM
