A/C help needed (yeah, I know there's a gazillion posts)
Old Sep 19, 2003 | 06:04 PM
AaronE's Avatar
AaronE
Default A/C help needed (yeah, I know there's a gazillion posts)
Sorry to start yet another A/C thread, but I can't find the information I need. Quick lowdown:
* A/C doesn't work at all. Seems the compressor isn't spinning up.
* A/C light is NOT flashing. Comes on normally and looks like it's working.
* Tried the Recirc + A/C switch combo to get codes, but it didn't do anything. (am I doing this wrong?)
* Don't know where the relay is, so I haven't checked that
* Don't know where the A/C sight glass is, so I haven't checked that either
* Previous owner said that the A/C kinda petered out last summer
Sounds like low R12 to me. How do I check that? And does that seem like a reasonable explanation? I'm hoping the comressor isn't bad, but if it is, there's one in the classifieds...
Thanks in advance,
-Aaron
Old Sep 20, 2003 | 10:04 AM
VVT-i's Avatar
VVT-i
Look for any kind of oil or heavy dirt bluid up around the compressor and one of the A/C line that run across the front part of the engine to the compressor. The SC400 are bad about leaking freon arond this area. Good luck.
Old Sep 23, 2003 | 08:53 PM
smelkony's Avatar
smelkony
Default Had same problem
I had the same problem when I first got my car a year ago. The car automatically stops the compressor from spinning because it knows it is out of the FREON (R12 or R134). So get it filled and the compressor should start working again.
Old Sep 23, 2003 | 10:29 PM
ChuH's Avatar
ChuH
There must be a leak. In my case had to replace the evaporator coil (~$500 including labor) on my 92 & 95 SC400.
Chu...
Old Sep 29, 2003 | 04:05 AM
UncleNick's Avatar
UncleNick
Default Re: Had same problem
If the system is low, the system has a low pressure cut-off switch to avoid damage to compressor. If you jump switch it should come on while adding freon but there is the other problem. If it is low, you have a leak somewhere. Most likely in the evaporator.
williamb82
GS - 1st Gen (1993-1997)
Feb 5, 2018 06:38 AM
xspsi6
Dec 12, 2012 03:10 PM
funcdocta
Aug 1, 2012 10:58 AM
blacksc4
Aug 12, 2011 08:02 PM
SharpCreas
Mar 13, 2006 09:20 AM
