ClubLexus - Lexus Forum Discussion (https://www.clublexus.com/forums/)
-   Maintenance (https://www.clublexus.com/forums/maintenance-11/)
-   -   2013 Lexus 350 won't start after maintenance light reset? (https://www.clublexus.com/forums/maintenance/934463-2013-lexus-350-wont-start-after-maintenance-light-reset.html)
sensei69 Dec 25, 2019 09:02 AM
Reset the triangular yellow light for oil change by by setting it to "Trip A" and turning button power off, the held the ODO button and pressed the power on button twice. THe odometer reset but now the car won't start and all lights are coming on. PLease HELP!
Nguyenerr Dec 25, 2019 01:55 PM
Is your steering wheel locked in place?
Edit: I'm assuming you might have locked your steering wheel while you were resetting the odometer. If this did happen, you need to turn the steering wheel as your turning the car on with your key. Hopefully this is the issue.
sensei69 Dec 26, 2019 01:57 PM
Thanks, bu no. Think I figured it our, the battery was drained. Once charged all set, I hope. What a coincidence
Nguyenerr Dec 26, 2019 05:20 PM
Probably from the cold weather. FYI, I'm sure you already know but batteries that has already died don't hold their charge as well. So might be time to invest into a new battery.
sensei69 Dec 30, 2019 04:24 AM
Thanks, will invest in a new one
