Negative Longterm Fuel Trims!? 1MZFE
Old Nov 20, 2019 | 11:54 AM
hypojam's Avatar
hypojam
Default Negative Longterm Fuel Trims!? 1MZFE
Hi. My 2006 Rx300 with the 3.0 vvti engine has around -10% long term fuel trims on both Banks.
I've changed the Maf new genuine toyota. I also changed the fuel pump assembly just incase fuel pressure was too high. No difference.
The car has 116k miles. Do there air fuel sensors start to misread the mixture coming down the exhaust when they get old?
Thank you for any help
Old Nov 24, 2019 | 10:27 PM
Yes they do. Can't remember if trims go positive or negative (not a diagnostic expert at all) when the sensors age. What is your mileage like?
Old Nov 24, 2019 | 11:00 PM
Jambeau's Avatar
Jambeau
I am not sure on how-to guide you, looking forward to see the suggestions of others.
Old Dec 1, 2019 | 08:05 PM
heidihidin's Avatar
heidihidin
i am betting on a vacuum leak
Old Dec 1, 2019 | 09:19 PM
hypojam's Avatar
hypojam
Negative fuel trims are sign off too much fuel. Not a vacuum leak.
I changed the air fuel o2 sensors now. Still negative trims.
I can only really put it down to injectors flowing/leaking abit more than they are supposed to. Car runs so well though.
mfigley
GS - 1st Gen (1993-1997)
Apr 17, 2020 12:34 AM
nivekwb88
IS - 1st Gen (2001-2005)
May 29, 2015 07:10 PM
Hayk
41
Aug 12, 2012 07:09 PM
stock98gs
Jul 1, 2011 04:20 PM
