Transmission
Old Dec 12, 2012 | 05:58 AM
NSeagle78's Avatar
NSeagle78
Default Transmission
Transmission wines and slips badly, HELP
Old Dec 12, 2012 | 07:01 AM
SC400slide's Avatar
SC400slide
In Recovery Mode
CL Folding 25,000
Uh...What kind of Lexus? What year? When does the tranny slip?
First thing to check is the tranny fluid level, but couldn't tell you anything if I don't know what model of lexus is having these issues.
Please be more specific...
Old Dec 13, 2012 | 04:06 PM
NSeagle78's Avatar
NSeagle78
Default transmission
I have a 1992 sc400 and I did drain and replace my fluid about 6 month ago and that is when my problems first started. I simply drained and replaced the filter only. I had read articles on this site on how to do tghis on the older trans.
Old Dec 14, 2012 | 09:22 PM
mitsuguy's Avatar
mitsuguy
Maintenance Moderator
Unfortunately, because the transmission was most likely not maintained properly its entire life, deposits had built up inside the unit. Addition of new fluid, whether just an incremental method or full flush most likely loosened these deposits and now you have a potential valve body or simply a clutch issue. Chances are if you retained the old fluid and put it back in, it would work better, but no guarantees on that...
look on the bright side, you can find transmissions for those cars all over the place and cheap...
Old Dec 15, 2012 | 07:15 AM
NSeagle78's Avatar
NSeagle78
Default thx
Thanks I just ordered one from Alabama for 500 plus 150 shiping installation will be another bill. I am located in Georgia.
silver250
Aug 13, 2021 02:32 PM
Kalogerus
Apr 9, 2012 12:49 AM
Vegas
Feb 7, 2012 02:52 PM
bguild
GS - 1st Gen (1993-1997)
Oct 10, 2008 09:26 PM
LazyAlex
Performance
Dec 16, 2006 10:32 AM
