All About Oil, Additives, and Oil Filters Superthread
List of filters and associations,
Main Manufacture --Sub- names of Brand filters using the main company to manufacture their filters. If you see a discretion, speak up with back up and I'll change the list. Fram
Toyota Mann+Hummel Mann Volvo Clarcor
Oil Manufacturers
Ever wanted to know who makes what oil? Here's the who makes what list. If you see any discrepencies, tell me and I'll make corrections.
Maker --Products Pay special attention to ExxonMobil, making a lot of oils that do well in Toyota v6's & v8's. Advanced Lubrication Specialties, Inc
CHS Inc
J.D. Streett & Co.
Warren Performance Products (WPP)
A Perspective on Filters
As a former Product Engineer for one of the household name filter manufacturers on the list, I'd like to add some perspective on filters:
1. You can bet that all filters made by a manufacturer are NOT equal. Filter makers make filters they supply to thier OE (original equipment) customers (i.e. Ford, GM, etc) to specs the customer sets. The filter makers are free determine specs for filters they sell in the aftermarket under their own label. Those filters may be of a better or lower quality than the OE filter. Areas where filters can differ include filtration efficiency (the percentage of particles of a particular size that are removed), capacity (amount of contaminant the filter can hold before becoming restricted), burst strength, pressure drop, etc, etc. Efficiency and capacity are determined for the most part by the filter paper, the performance of different papers can vary greatly, and differences are not possible to see by eye........lab tests under carefully controlled conditions are required. There's a lot of 'black majic' in what the paper manufacturers do and also a lot of jockying for position to get exclusive rights to the best paper to get an advantage over filter competitors. 2. If a filter manufacturer supplies OE (original equipment) filters to a car or engine manufacturer, then they are familiar with the specs required for those filters. (Whether the filters actually meet all the specs is a different question depending on the integrity of the filter maker. Filters are a comodity and the market is extremely competitive; I've actually seen out-of-spec product get knowlingly shipped just to keep production running and revenue coming in.) 3. If a filter maker doesn't provide OE filters for a particular application, they may not have access to the official specs for that filter and must "reverse engineer" their own filter to copy an OE filter. They obtain OE filters however they can, usually from a dealer. The quality of the final product depends on the skill and integrity of the filter maker. 4. Unfortunately, it's impossible for the the consumer to independantly determine which filter is best, and it's difficult to know which filter maker to trust. It's important to me to buy a filter that's most likely to meet the specs set by the engine or car manufacturer......it's their reputation that's "on the front lines" if there's a failure. To maximize the chance of putting the best filter on any car I really care about, I either buy a filter from a (trusted?) filtermaker that I'm confident has access to the official product specs, or from the car dealer. I always buy the best filter available for the application. To me it's worth the extra money. I use filters from 5 different sources (some dealer-bought, some aftermarket) for the variety of cars we now own. Cheers, Bob P.S. It's been a number of years, but I contacted the maker of a widley used "performance" filter for some technical info. The info they provided proudly showed a reduction in pressure drop which would result in greater performance. However, what I did not like was that the efficiency in removing particles of a particular size dropped from 98% to 97%. This may seem like an insignificant change, but if one considers that the number of particles of that size getting thru increases from 2% to 3%......a 50% increase in dirt that filter allows into the engine! .......but not my engine.....not for just another 2-3 hp near redline. |
The new AMSOIL filter are NOT made by Clarcor. The EaO filters are primarily assembled by WIX using media from Amsoil and Donaldson.
http://www.modernoils.com/EaO_Oil_Filters.html |
Castrol Full Synthetic 5w-30, no oil burning problem at all.
Seems like Royal Purple is also manufactured by Champion Labs. Here are a couple of vids explaining it's build:
http://www.youtube.com/watch?v=floUZGP6NZM and http://www.youtube.com/watch?v=K7UGmAEqwHI |
Toyota genuine oils are unique products designed by Toyota for Toyota vehicles, even when Toyota hires American companies like Mobil to formulate Toyota oils. Mobil even admits this on it's own website in regards to transmission fluid: See: http://www.mobiloil.com/USA-English/...smissions.aspx
Mobil says: "Mobil 1 Synthetic ATF and Mobil Multi-Vehicle ATF are suitable for use in Toyota applications where Toyota T-IV type product is recommended. However, the Toyota/Lexus ATF is specifically designed for those vehicles and will provide optimum performance." |
Lexus Canada recommended oil weights..
I emailed Lexus Canada for oil weight information (it was a detailed email) and this is what they sent me. Keep in mind it's from Lexus Canada. Lexus USA might have different recommendations, though I don't know why they would - the engines are the same, Canada or USA.
http://img35.imageshack.us/img35/9313/lexusoil.jpg The small print at the bottom shows - ""TCI has made all possible efforts to ensure accuracy of this document. In the event of specification dispute and/or inconsistency, the owner's manual prevails. Note: Engine oil viscosity on oil filler cap specifies oil viscosity utilized during engine factory fill. For service refill, other oil grade options may be available for the model. This information is also available on ETAS: Dealer Communication (16) *Please discard all previous versions." |
I am closing this thread until I have time to prune it. It will stay sticky'd and if anyone has any more info to put in it, PM myself or MitsuGuy and we will add it in. I will be trimming this down and turning it into an "All about oil-Superthread" and reopening it. I am doing this to try to trim down the number of stickies we have at the top of the forum, in the hopes the maintenance forum will get a little more activity/visibility.
Again, nobody has done anything wrong, this is strictly an organizational thing.:) EDIT: Ok, trimming done, Thread is open again. Lets keep this thread on topic and the chit chat to a minimum, just so that we can maintain only correct info in this thread. If you have valuable input, by all means put it here, but lets leave the "I have been using xxxx-brand oil for xx,xxx miles..." etc, out of this thread so we can keep all the info in one place and people dont have to go sifting through the random stuff looking for it. :) Thanks all. |
nice, like the chart
+1 on the chart...most helpful. :thumbup:
I find that Castrol Synthetic Blend with Lucas Oil Stabilizer keeps the LS400 running like new.
did i miss what company makes Mobil 1 ?
or are they there own oil ? |
Mobil is part of ExxonMobil, which is the worlds largest company by revenue...
http://en.wikipedia.org/wiki/ExxonMobil |
is there anything wrong with using Motul Multi ATF for Lexus since it is Type T-IV compatible?
thanks http://www.motul.com/system/product_...pdf?1392673158 |
