'98 GS 400 starting problem
Old Mar 12, 2002 | 06:25 AM
rvelez's Avatar
rvelez
Default '98 GS 400 starting problem
Can anyone shed some light on this please? On my '98 GS400, I've been having problems starting the car. It seems to have something to do with the ignition system. I've had the car's complete electrical system checked and it proved okay both times. My Lexus dealership said that they strongly felt it was the ignition module and I okayed them to replace it a couple of weeks ago (at my expense of $1200.00). Well, guess what, that was not the problem and it is currently back with them being looked at again. Maybe I got some bad pins in the module itself. Anyone have anything similar happen to your car? Thanks.
Old Mar 12, 2002 | 09:45 AM
ShowGSLuVv's Avatar
ShowGSLuVv
try resetting the ECU, maybe that might help
ShOwGS
Old Mar 12, 2002 | 09:49 AM
///MDex's Avatar
///MDex
Can you be a bit more specific on what exactly happens when you turn the key?
Old Mar 12, 2002 | 10:59 AM
rvelez's Avatar
rvelez
Hi: What happens is when I insert the key, it actually turns in the ignition itself, all the dash lights come on, etc., but the car does not start (does not even turn over), almost as if the starter is bad or alternator. After jiggling the key inside the ignition a bit, it will usually start shortly thereafter. Then again, at other times (especially after the car has been running a while), sometimes there is no issue with the ignition. Hope this helps. Thanks for your comments and suggestions. I'll try anything at this juncture.
Raul
Old Mar 12, 2002 | 02:05 PM
GS430 GUY's Avatar
GS430 GUY
CL Folding 200,000
rvelez,
It sounds like the transmitter in the key is going, since the 98+ GS's transmit a code to the ignition before it starts. Does this happen on all the keys to the car or on just one set? Also if you have speedpass on your keychain it can interfere with the transmitting of the code from the key to the ignition. Keep us updated
Old Mar 12, 2002 | 02:22 PM
rvelez's Avatar
rvelez
Hi: Thanks for the response and suggestions. It actually is happening to all three of my keys (the last one being a brand new key from when Lexus installed a new ignition module). What is "speedpass". I have not heard of that term yet. Hey, nice to hear a fellow GS man with the Borla exhaust system - isn't it awesome! Take care...
Raul
Old Mar 13, 2002 | 08:41 PM
ShowGSLuVv's Avatar
ShowGSLuVv
Let us know if u get it fixed or not, IM curious as to what the problem really is
ShOwGS
Old Mar 13, 2002 | 08:47 PM
GS430 GUY's Avatar
GS430 GUY
CL Folding 200,000
Raul,
Speedpass is for Mobil and Exxon gas, instead of paying with a credit card, you just swipe it by a receiver since it has a built in transmitter. www.speedpass.com The transmitter has been known to interfere with the engine immobilizer from time to time, that was why I asked. I am clueless as to what the problem could be, but do keep us all updated on what happens. As far as the Borla exhaust, I love it
Old Mar 13, 2002 | 08:52 PM
rvelez's Avatar
rvelez
Hey Team: Thanks for the inquiries and suggestions. I was at the dealership earlier today and they feel that when they coded my keys for the new ignition module they installed the last time they had the car, that somehow the keys were not coded correctly (j-u-s-t a tad off somehow) and that could very well likely be causing the car to act up intermittingly. I sense they feel real bad about it because they also said that "coincidentally" my starter is starting to fail, so they are going to install a brand new one gratis for me - this way I don't have to run at least the starter through my third party warranty company and not have to spend anything on my deductible. Can you say: "We messed up Mr. Velez". CIAO
Old Mar 29, 2002 | 05:02 PM
awj's Avatar
awj
Bluegr*** Performance
There is a thread in the SC forum you may want to check out. I'm having the same problem now. I'll post the link with an edit. Let me know how it turns out.
https://www.clublexus.com/forums/sho...1&pagenumber=2
I don't have the transponder and that may very well be, also if they are replacing your starter anyways, that will correct any contact problems. Good thing too, w/ the v8, that thing is hidden under the intake manifold.
Old Mar 31, 2002 | 07:41 PM
DevilDog's Avatar
DevilDog
I have never heard of "just a tad off" when recoding keys. I still think you have an imobbilzer problem. Next time it happens look to see if your security light is flashing while the key is in the ignition. That means the engine ecu did not reconize the code. Yes, it may be a speed pass, or another key. Any other keys on your ring with an imobilizer chip?????? Ford keys are common for this!
DD
Old Apr 1, 2002 | 06:41 AM
rvelez's Avatar
rvelez
DD: Thanks for the post. What eventually happened in the end is that they did replace my starter as a goodwill gesture (no cost to me) and did rekey the iginition module (they said it took them several hours to do this part as well). I've had the car now for about 2 weeks with no re-occurrence of the original problem. It seems they may have found the solution (finally). When the dealership called me about a week later to do a survey, in a nice way, I let them have it about my dissatisfaction and inconvenience they put me through. For my troubles, I get a free complete detail package (inside and out) that will take them all day to do. So, all in all, not too bad. Safe driving....
rvelez
Old Apr 3, 2002 | 05:43 PM
JYOO
Guest
Posts: n/a
I knw it couldnt of been an engine problem. Its a Lexus
Old Apr 3, 2002 | 07:37 PM
rvelez's Avatar
rvelez
Hello: You're right - it's a Lexus. I noticed that you and I have the same model. Mine's also a '98 GS400, black exterior with the Lexus 17" chromes, saddle interior with nav system, Borla exhaust. Have a question for you. I still don't know what the down buttons on the steering wheel do or what the ECT-PWR button does to the car when engaged. Can you explain it to me please? Thanks.
Raul
Old Apr 4, 2002 | 01:37 PM
JYOO
Guest
Posts: n/a
Down button is to shift down when you are in manual mode. Put your car in manual mode when you are stopped, youll notice a 5 in your dash, then push down until it goes down to 2. It doesnt go down to 1 cuz it automatically shifts from 1-2 anyways. And power button is just that, it gives u more power . Actually it just redlines higher and shifts firmer...try it!
lexo1998
Aug 9, 2025 12:46 PM
credle89
Jan 19, 2014 06:08 PM
TEXAS83
Jan 22, 2011 06:19 AM
OceanView
Maintenance
Mar 3, 2005 07:19 PM
///MDex
Jul 20, 2001 04:56 PM
