93 GS300 is throwing codes #24 & #31
Old 09-14-04, 03:46 PM
johnee78
johnee78's Avatar
Default 93 GS300 is throwing codes #24 & #31
I am aware of what these codes mean but I would like to know if anyone can help me diagnost the problems and how to fix them..My car has been running very bad and I really need help..
Old 09-15-04, 03:27 PM
VVT-i
VVT-i's Avatar
Look like you got a bad air flow meter because code 24 is intake air temp. sensor and code 31 is volume air flow meter circuit malfunction. Both codes relate to air flow meter.
Old 09-15-04, 04:46 PM
johnee78
johnee78's Avatar
So , if i replace the air flow meter the codes should disappear and my car should stop runniing like crap and start to get decent gas mileage?? I have done just about everything else and I would really like to get my car running the way it used to..thanks for youe help so far..
Old 09-16-04, 02:54 PM
VVT-i
VVT-i's Avatar
Replacing air flow meter is just a start point, because your car may have another hiding problem. Such as EGR tube clogge up( every well know for the GS300).
Old 09-17-04, 05:22 AM
johnee78
johnee78's Avatar
So I am going to replace the air flow meter and I will remove the EGR valve to clean it just in case..When I do these 2 things should my car run good again and it shouldn't throw anymore codes??Thanks for your help ...
Old 09-17-04, 09:13 AM
LB Lex
LB Lex's Avatar
The airflow meter can be expensive. If you think it's bad, why don't you try cleaning it by spraying electronic contact cleaner? If you have an aftermarket air filter, sometimes the oil coats the meter and messes it up. Worth a try.
Old 09-17-04, 09:28 AM
johnee78
johnee78's Avatar
I tried cleaning it and it still is bad..I don't believe in oiled air filters just because of this..I just use the stock filter..The meter new is around $800, but I plan on buying a used one until I have enough money to buy a new one..
Old 12-28-08, 06:31 PM
VipDout
19x11.5 -51
VipDout's Avatar
air intake temp circuit malfunction (anyone know where this is located ?)
Old 12-29-08, 05:05 AM
mitsuguy
Maintenance Moderator
mitsuguy's Avatar
it's in the mass air flow sensor...
dicer
02-19-16 05:45 PM
airtraffic
SC- 1st Gen (1992-2000)
06-05-11 09:36 PM
johnnyg66
05-01-11 05:56 AM
Quick Reply: 93 GS300 is throwing codes #24 & #31
