Brake Bleeding with Hand Pump System
Has anyone used one of those brake bleeding systems that you put brake fluid into a container that has a pump handle on it and then attach it to your master cylinder? It looks like a very slick system that would make bleeding the brakes a very quick project. Would it matter what car you have to use this sytem? A friend of mine who owns a Porsche 930 Turbo, bleeds his brakes with one of these and will let me barrow it. Thanks.
To get as much of the old fluid out as possible...empty the brake fluid reservoir with the Mityvac vaccum and refill completely before proceeding with brake bleeding.
https://www.clublexus.com/forums/sho...d.php?t=185967
I'd try and take the simplier approach. Find someone to pump the pedal while you bleed the fluid out. I was about 7 when a neighbor came over and asked if I could step/pump the brake pedal. These days, I get the Mrs. and I'm usually done in less than 20 minutes.
if your lonely like i am you can bleed the brakes by yourself. it can be a little time consuming getting in and out of the car everytime the reservoir needs to be filled. all you need is a clear plastic tube and clear glass bottle.
TunedRX300 I have one more question for you. The rubber connector and hose you purchased. Does it snap on to make a seal? I mean, if it connects up like a seal then there would never be a problem with any air getting back into the system if for some reason the one way valve does not trap shut quickly enough. According to the link to the BMW guy in your "How To" link, his problem with the Speedbleeders was that he did not feel confident the one way valve closed fast enough and a small amount of air would get into the system before the valve closed. Any feeling on this?
