1st Gen LS 400 Timing Belt
Old 03-11-05, 02:59 AM
Herm
Herm's Avatar
Question 1st Gen LS 400 Timing Belt
Would appreciate any coments (or pointers to existing posts) on when to change 1994 LS 400 Timing Belt.
Also, does the 1994 LS400 engine get damaged if he Timing belt breaks ?
Thanks, Herm
Old 03-11-05, 03:25 AM
EXE.UCF10
VIP|EXEstyle セルシオ
EXE.UCF10's Avatar
The timing belt is usually replaced at 90k miles.
Old 03-11-05, 02:52 PM
VVT-i
VVT-i's Avatar
The 1994 LS is non-interference engine. If the timing belt break the engine will be fine, but you may stuck in the middle of nowhere...
Old 03-11-05, 04:53 PM
PERRYinLA
PERRYinLA's Avatar
No need for pointers- the search function will work fine for this subject. There's plenty of posts on how the belts are built to last, and how rare it is to find one that breaks.
Old 03-12-05, 12:53 AM
Herm
Herm's Avatar
I did try searching on the subject, but did not have much luck. Perhaps it was my inexperience. If someone knows of timing belt posts specific to the Ist Gen LS, I really would appreciate a pointer. That's what is great about this forum, we all try to help each other. In the past I have posted some useful info on power steering and instrument cluster issues. Thanks, Herm
Old 03-12-05, 09:21 AM
PERRYinLA
PERRYinLA's Avatar
Indeed you have.
I have a 1st-gen SC400, and our engines are the same. Try expanding your search to cover those models as well.
Old 03-12-05, 02:45 PM
saber
saber's Avatar
They've lasted as long as 191,000 and busted as soon at 92,000. Timing belt life varies alot depending on driving habits.
Calm, easy going highway drivers that tend to maintain a steady speed and who almost never floor the gas pedal can comfortably wait until about 15-20 years or 120-140,000 miles.
Hurried drivers that are constantly weaving in and out of traffic, speeding up and slowing down and who accelerate hard from stop signs and stop lights should change the belt somewhere between 60,000-90,000 miles.
Old 03-12-05, 07:20 PM
joshthorsc
joshthorsc's Avatar
Also, try to stick with oem timing belts. When I got my timing belt changed, I only stuck with oem. Also, you might want to change the drive belt, spark plugs and wires, cam seals, front crank seal, water pimp, and the tensioner while doing the t-belt. It'll save you labor cost and time to do it all at once. I got everything done for around $1,000 for parts and labor at a small shop. The guy did a great job too!!! Lexus wanted $1200 just to do the t-belt and h20 pump, and that includes labor!!!
~Josh
Old 03-12-05, 07:22 PM
joshthorsc
joshthorsc's Avatar
~Josh
Ooops!! I meant water pump; not water pimp. My mistake.
~Josh
Old 03-13-05, 01:22 AM
PERRYinLA
PERRYinLA's Avatar
It's called the edit button. Look into it.
Old 03-14-05, 07:19 AM
damon
damon's Avatar
I have a 94 with 167,000 miles & an original TB. Keep a kit in my trunk with the following:
*** Some part #'s are Dayco , not oem.
Parts List:
13568-59045 Timing Belt
13540-50030 Tensioner
13503-0f010 Idler Bearing Left
13505-50022 Idler Bearing Right
Front Cover Gasket
11319-50010
11329-50010
11346-50010
11347-50010 2 Total
11357-50010
90311-A0001 Front Crank Seal 5060885 Serpentine Belt ( Dayco Part # )
89255 Tensioner ( Dayco Part # )
89026 Pulley ( Dayco Part # )
Electrical
19101-50020 Dist. Cap
19102-50020 Rotor
Spark Plugs
BKR6EIX-11
90311-38036 Cam seals ( 2 Total )
Cooling:
16100-50022 Water Pump
90916-03084 Thermostat
16325-62010 Water Inlet, Gasket
16571-50021 Upper Radiator Hose
71538 Lower Radiator Hose ( Dayco Part #)
dmhosler
06-17-21 01:36 PM
430SLOwner
08-17-19 02:31 PM
thadword
06-06-08 10:25 AM
Nyxtopouli
12-29-07 09:46 PM
Quick Reply: 1st Gen LS 400 Timing Belt
