90915-YZZD1 vs Mobil 1
I've searched through many threads and nobody has actually really compared these two filters. Which one do you guys recommend, the Toyota 90915-YZZD1 or the Mobil 1 brand?
I don't think you'll go wrong with the factory filter.
The Toyota 90915-YZZD1 was designed by Denso - a Japanese company that has supplied Toyota with
most of its filters and numerous other parts since the 1950's. Denso thus helped Toyota establish it's world renowned reputation for building the most reliable and durable cars in the world. Now If the Denso company did not exist and Toyotas were made with parts made by Bosch, Delco, Mopar, Motorcraft, Mobil, etc. what kind of car would a Toyota end up being? Answer: Just another unreliable and unexceptional car brand like Ford, Volkswagen, etc. If that unexceptional standard of reliability is good enough for you, then feel free to use all the aftermarket parts, filters and fluids that are found in chain type auto parts stores. |
I use the D3 with no problems.
Thanks for your input.
both are excellent filters and will perform the job required. I have used both. K&N Gold is also an equivalent filter.
in price it would be 90915< Mobil1 < K&N. steviej |
Originally posted by steviej both are excellent filters and will perform the job required. I have used both. K&N Gold is also an equivalent filter. |
Well there ya go! Neither OEM nor aftermarket filters are perfect. I'll stick with either the K&N or Mobil 1 oil filters.
Originally posted by Lexusfreak Well there ya go! Neither OEM nor aftermarket filters are perfect. I'll stick with either the K&N or Mobil 1 oil filters. |
The 90915-20004, a true Japanese-quality Denso filter, is the way to go if you can still find them.
Originally posted by nthach Honda has been using Fram for a while. I made it a point to get only Filtech/Toyo Roki filters when I change the oil on my neighbor's Accord. |
Delar can still order it but is alot more.
I haven't heard any problems with either K & N or Mobil 1 oil filters. :) Been usung them on my cars for 4 years now. :thumbup:
if you can get 90915-20004 or TRD filter part# 00602-90915-007 is the same
Originally Posted by kreativ
How do you tell between them these days? The info I have on differentiating between them is a couple years outdated.
I use K&N oil filters in my cars, truck, and motorcycle. The best in my opinion!
I cut apart the filters in my camaro every time i change the oil, since i drag race it often. The construction and quality of the K&N filter is by far the best ive seen. |
