Engine Won't Start
99 GS 400
When i turn the ignition on, it makes the noise of an airgun trying to take off a nut on a tire. with the RPM flickering. lights dim, but car won't start. Does anyone know what is wrong with my car? Thanks for any help!!!!!!! |
Try to jump start it. You may have a weak battery.
Thanks. will try that tonight. if that doesn't work, any other suggestions?
try jumping the starter itself. Maybe that'll help. Grab a screw driver, and just arc your hand into your engine bay and touch the two leads on the starter with the screw driver. Once you get power to the solenoid, it'll put the plunger down, turn the armature and it'll engage the pinion gear to the fly wheel or the flexplate. I think its the battery tho
Originally posted by Woogie try jumping the starter itself. Maybe that'll help. Grab a screw driver, and just arc your hand into your engine bay and touch the two leads on the starter with the screw driver. Once you get power to the solenoid, it'll put the plunger down, turn the armature and it'll engage the pinion gear to the fly wheel or the flexplate. I think its the battery tho |
Yeah, you're hearing the starter solinoid clicking rapidly because the battery is dead... might be able to charge it and bring it back to life.. or you may just need a new battery.
I'm having a remotely similar situation...when I turn the key I'll hear it click but not turn. After another try or so, the starter will turn and the car will start. Any thoughts if this is battery, starter or ?
Originally posted by RA40 I'm having a remotely similar situation...when I turn the key I'll hear it click but not turn. After another try or so, the starter will turn and the car will start. Any thoughts if this is battery, starter or ? |
Originally posted by hyperopt Could be either or both. Start with the simplest item (battery in your case) then progress to the more difficult item. Be absolutely sure it's not the battery before taking the next step. A buddy checked the battery a few days before and his tester indicated it was putting out 577 CCA and the alternator was charging. Battery is 2 years old so anything is possible. :confused: I hear that starters are not common items for replacement...hence Toyota's decision to bury it. I just don't know how to determine it. Lexus wants a $91 diagnostic fee. :thumbdn: |
RA40, You can not test a Battery with a volt meter ,that is not the proper way,a load tester is needed.
RA40 ,first replace those stock battery clamps and check out the negative at ground ...............Also there is a recall on the 2gen. LS starters ,they have a problem with the connection and then put in a good battery :
https://www.clublexus.com/forums/sho...optima+battery |
Also check for short circuit while the car is at rest (everything off). A short will allow electrical leakage and impairs CCA between charges. This might explain why your car cranks poorly when sitting for an extended period of time. You'll need an ampmeter to quickly gauge the current drain while the car is at rest but then your meter is dead. :thumbdn:
An update in my situation...it was the starter. The original battery was still good but I went ahead and replaced it with an Autolite Platinum 770 CCA. The new combination sounds much different and it starts faster. One turn and usually you'd hear the starter whine but now the engine is going almost immediately. This little fix was $780. :cry: At least I shouldn't have to worry about it for another 80K miles....fingers crossed.
Thanks to Longo Lexus...this was the most pleasant experience I have had at a dealer for service. |
Glad you got it fixed! Hehe, i knew it was the starter ;) The price sounds about right, steep, but hey.. look where the starter is.. under the intake.. takes some time to get that replaced :)
Originally posted by RA40 An update in my situation...it was the starter. The original battery was still good but I went ahead and replaced it with an Autolite Platinum 770 CCA. The new combination sounds much different and it starts faster. One turn and usually you'd hear the starter whine but now the engine is going almost immediately. This little fix was $780. :cry: At least I shouldn't have to worry about it for another 80K miles....fingers crossed. Thanks to Longo Lexus...this was the most pleasant experience I have had at a dealer for service. |
| All times are GMT -7. The time now is 09:28 AM. |
