LX570 Height Sensor Issue: Delta 1"+
Has anyone experienced a height difference of one or more inch of the rear left height compared to the rear right height? For example, the driver's rear side is measured to the top of the lip of the wheel well at ~34" while the passenger rear wheel well is measured at ~35". From the back view, you can see that the vehicle is tilted or leaning to the driver side. The mud flap heights make it more apparent. Could this be a height sensor problem? The car is parked leveled in the garage.
The fronts measured OK and equal. I am going to take it to the dealership in the middle of next week.
https://forum.ih8mud.com/threads/lx5....918190/page-2
Thank you for the link. I just got back from the Sterling McCall Lexus @59 and the problem was not fix. The service adviser said it was but clearly not when I got there. Nor did they perform the seat belt recall. What a waste of time with a bunch of incompetent people. I will try Northside Lexus in a couple of weeks. I called Lexus corporate mental line, and they are clueless as usual.
I measured on level grounds. It is left to right (side to side). Sterling McCall really sucks, and the service advisor have the audacity to ask for 10/10 review? I have no positive words to describe such behavior.
I wanted to bump this thread to see if there's an update on the issue. I just picked up a 2020 LX570 and found the same problem as we'll. Right rear is about 35" while left rear is about 34". Front heights are equal.
In the link above for ih8mud.com, look at post number #332. There's a video for the sensor adjustment. Having said that, I think the root of the problem of leaning is not the adjustments of the sensor. It's the actual accuracy of the AHC system to go from high, low, and normal. My LX measurement varies from 1/2" to 1.25" difference from time to time. I have not adjusted my sensors. That means the AHC leveling will have a tolerance of up to a 1". This is more noticeable in the two rear wheels than in the fronts.
Two Lexus tech have told me that it is within specification for this system. I don't know if this is true while the vehicle is motion. I have over 10K miles and no issue with tire wear. I've noticed this leaning stance on models up to 2020. Long story short, Lexus does not think this is an issue that some of their trucks do lean to one side. Some are more severe than others from time to time.
Thanks for the update. It is good to hear you haven't found issue with tire wear. I can only hope that means the car did level itself over time when it's moving. I did see the post on ih8mud but I don't think that actually solves anything in our case. My LX measurement varies like yours so even if I had adjusted the sensor, it would have only worked for THAT particular time. Anyway, I really don't understand why my brand new 100k vehicle wouldn't level in the garage. With 1 inch difference, its stance actually looks pretty ridiculous. I plan to take the car to the dealership near me and see what they say about it. I am eager to learn more about how this AHC system actually works.
Anyone have any update on the resolution?
I've been having the same issue on my 2017 where the driver side front is sagging. Taken to 2 different dealerships only to be to told that it's normal. Honestly, just doesnt seem like any technicians are familiar with LX's. Was even told that the driver side "air" suspension is lower to help drivers easy access to the vehicle...wtf
Anyone know a good NJ Lexus dealer who are familiar with LX's? Or even private mechanic?
