Which aluminum oil filter base for 2013 LX570
Good Morning, Has anyone found a good part number for the aluminum oil filter base (oil cap assembly) that will fit my 2013 LX570 engine?
Many Tundra guys have replaced the plastic base with an aluminum one, however the center perforated tube must be removed from the old base and installed on the new aluminum base.
and you do have to re-use the old filter drain plug. Thanks
It's a Toyota Venza part... Check Aluminum Oil Filter Base. Toyota PN 15620-31060. A very simple switch-over.
hth
Steve
hth
Steve
