As gas prices rise, will you deviate from Premium?
#61
I think that for some of us, it has absolutely nothing to do with money. We just would like to know the truth.
Rki2019 (01-07-20)
#63
I had a look at the compression ratio of the3UR-FE 5.7 litre V8 motor and it is 10.2.
In my personal experience with other V8 gasoline engines, I found that I needed to use premium to avoid pinging for compression ratios above 9.5
Based on this rough guide, and knowing that the LX570 has a conventional motor with a 10.2 compression ratio, I would definitely not skimp on fuel costs, as it may be detrimental to the longevity of the motor. I am not comfortable relying on the ECU to keep retarding the ignition advance to avoid pinging.
#65
Most modern engines have compression ratio above 10 and they work fine on regular. And I don't know about any significant problems with Tundra/Sequoia/Land Cruiser engines.
#66
Have you seen any posts to "messing up" an LX on either forum? Plenty of threads in the 200 series forum on Mud re: octane...I'd suggest educating yourself.
^Thread. I pray.
Craigyyy (09-24-18)
#67
You are bit too sensitive. Educating oneself would be to follow what the manual states. But it is all good, we all have our own opinions.
REDHORSE (07-06-18)
#68
And I do know what "they" say about opinions.
The question was are you or anyone aware of an engine failure that can be attributed to using regular fuel?
ClaytonW (07-05-18)
#69
The manual also alludes to "lifetime transmission fluid"...not sure how that works on a truck with a 250K mile design life. In some cases, common sense may indeed over ride the manual. BTW, what year is your LX?
REDHORSE (07-06-18)
#70
I am not quite sure if for a vehicle approaching $100,000 is abiding the manual the best idea. Hankinid is right. But if you believe in "lifetime transmission fluid"... The problem is that the manual is not only written by technicians but also by the marketing department. Common sense sometimes work better.
#71
Yes, but why would that matter if you're already discounting the manual written and delivered by the company that built the vehicle. Lexus and their manual are 100% correct for anyone that wants to abide by it. If you don't so be it, but don't pretend to be an expert on a vehicle you neither designed or manufactured to mislead others into ignoring the manual under a nonsense statement of "common sense". Ignoring the manual delivered with a vehicle approaching $100,000 is not common sense.
I am not pretending to be an "expert"...if I need one, I know where to find a few. I also spent some money on a set of shop manuals and TIS...that not only tells me what to do and when, but it also lets me know if it's over my head. E.g., no mention by Toyota about changing the fuel filter. Are you saying that the same filter will last through the design life Toyota states? I neither designed nor built the first batch of 8 speed transmissions, but more were replaced early on due to solenoid failures at no cost to the owners. No car maker is perfect. I'd say that's common sense.
#72
If you guys really think that you cant run 87 in a 570, I've got a bridge to sell you
Literally the same motor at the tundra/LC. Now, throw the Magnuson S/C on, then you have to run 91.
#73
#74
