Cargo liner for 2011 LX
I recently purchased a 2011 Lexus LX and would like an all weather cargo mat. Weather tech does not offer a custom cargo liner for that vehicle. Would a 2011 Land Cruiser cargo liner fit?
I have Weathertech liners for both of my LX's, a '10 and a '13. I bought them both on Amazon. They're both all weather. Unless they've stopped making these they are out there.
Your choices are either Husky Liners or Weather Tech. If "all weather" means it may get muddy and sloppy back there, Husky has higher sides. I have WTs in both the LX and Land Cruiser. No issues. No back seats in either truck after their first week home. WT's fit perfectly in the 100 series. The 200 needs a bit of extra space-filler near the seat brackets on both sides. You'll understand once the seats come out. So the Cruiser is set up with factory carpet, WT cargo liner with spacers where needed, and cheap wall-to-wall carpet over that. I bought enough carpet that I can simply cut a replacement (seems like about once a year). Look for cut-off's or short rolls at HD or Lowe's or a carpet store.
hth
Steve
hth
Steve
I normally use Weather Tech but in my LX I went for the Husky Liner and I'm very pleased. They feel a bit more rubbery than the WT. Very high sides, good fit in all locations. If you want to retain use of the third row there are four areas with raised ribs that you cut out so the seat bracket can engage.
Actually found the Lexus rear all-weather rubber cargo mat really nice (and I'm generally a WT guy). http://www.lexus.com/models/LX/accessories ... was in stock at dealer, paid $90ish. You try that route yet?
Or ebay here: http://www.ebay.com/itm/Lexus-LX570-...2/111817921259
OT, but saddles and boots that are clean normally go in bags.
Originally Posted by Finnie
The seats will be staying in for now. Weather tech no longer has them available on their website. I'll check Amazon. Thank you for the help.
I, too, just bought a 2011 and put WeatherTech floor liners in both the front and back seats. However, I could not find one for the cargo area. Their site says they do not offer one and they suggest another manufacturer's cargo liner. I found one online as well, but was suspicious as to why you couldn't buy it directly from WeatherTech. I called WeatherTech and they said that they do not make one for the 2011 and if I found one online, it was a fake and not to buy it.
That said, I did find an all rubber, grooved cargo liner that Lexus makes that provides similar protection, has the Lexus logo on it and fits perfectly with cut outs for the seat latches that are removable for when you want to put the third row down. I have been happy with it so far.
In case you haven't already found another solution for your LX (like the Husky Liner or Lexus OEM mats that others have recommended), I can tell you that WeatherTech item 40356 does work for the most part in the LX. I have a 2017 but I think the third row seats and cargo area dimensions/locations are the same as the 2011. I say "for the most part" because it is not a perfect fit. The 40356 is made for 2008-2017 Land Cruisers and Weathertech does not market it for the LX. As far as I can tell (and I used to have a 2014 Cruiser), the main issue why they don't market this for the LX is because in between the two "posts" that house the swiveling mechanism of the LX third row seats is a hump that I think houses the power folding motor. In the Cruiser, it doesn't have that hump. The Weathertech liner has "wings" that are supposed to lay flat between the posts (and does in the Cruiser; but does not on the LX). In any event, I still use it for my LX and think it works just fine.
