Tire recommendations
#31
I'm running 46psi. Only need 43 psi but with 46 I won't need to adjust the air pressure during the winter here in north Florida. Love the ride and feel. These big heavy Suv's should come with truck tire's from the factory. I went with the 285/55/20 BFG for the wider tread width plus the looks of the BFG AT/KO2's
#32
I'm seriously thinking about the Terra Grappler G2s when my Defender LTXs wear out. Seems to have a nice blend of ride and a more aggressive tread pattern. Anyone have any experience with them?
#33
I run BFG KO2's on my LX470, Just put Michelin LTX Premiers on my RX. The LX570 still has stock tires from the dealer. Im watching this threat for thoughts on that one.
#35
Pros: They give a very nice aggressive look, great treadwear (still look almost new), handle great in all conditions (dry, wet and snow)
Cons: kind of noisy on highway - and for this reason I will not get these in future.
I'm considering Defender LTX or Toyo Open Country for my next set of tires - will hopefully own an LX570 by that time.
#36
I have had these on my GX for almost 3 years with 30k+ miles..
#37
The Nittos are definitely louder than stock. I was trying to go for a more off-road type look, so definitely compromised comfort for that - not much but noticeable enough to have buyers remorse afterwards. They look great and handle well in all conditions, but I will try a different brand for sure next time for comfort.
Chocolate (10-19-17)
#38
I’m running BFG AT/KO’2s 285/55/20 on stock Lexus rims 46 PSI I run 🏃 on sport mode. Feels great. Lexus should’ve put all terrain truck tires on these vehicles to begin with
#39
Just purchased 2016 18" Land Cruiser rims. I plan on putting 18" Michelin LTX tires (Same as Clayton W did - see his previous post). I need to get tire pressure monitoring sensors. Will the sensors Toyota sells at the Toyota dealer work on the Lexus? Or, do I need to buy the sensors from Lexus?
Also, where can I buy the Lexus center caps for this rim?
#40
I bought my sensors from Lexus. But probably new generation of Toyota TPMS sensors would also work. The best solution (if you can) is using the sensors from your original OEM 21" wheels.
Just FYI, my local Toyota dealer was not able to program the sensors, I had to go to Lexus. They are usually not able to read the sensor IDs when they are mounted on the wheels. They must remove tires first. So the most important thing is writing the sensor IDs first before you mount them. If you know IDs, then everything is simple. You can for example buy ATEQ TPMS QUICKSET to do it (about $130, very useful tool if you have more Toyota/Lexus cars).
Center caps - I still have Toyota, no big deal for me. But I know that LX is sold in Russia with Land Cruiser 18" wheels so definitely, it exists and can be purchased.
#41
Do they have to "REMOVE" the entire tire out of the wheel to see the TPMS sensor? I thought they can just deflate the tire so that the tire can be pressed down to reveal the TPMS SENSOR to see it? The just reinflate the tire back up.
Good choice :-)
#42
Thanks Clayton. I ended up purchasing the sensors and tires from my local Lexus dealer. I have them do all my maintenance on 3 Lexus vehicles, so they know me there and pretty much matched local tire store pricing. And they threw in a free alignment as well. Sensors were $79.00 each and everything with installation, tax etc was about $1400.00 or so. While I probably could have saved a little elsewhere, this allowed me to have one company do it all and warranty the tires, sensors, installation, etc. I too kept the Toyota center caps. If I have time, i'll upload some pics. Thanks for all your help. The car's drive is significantly improved, especially over rough roads, with almost no loss in handling on the twisties!
The following 2 users liked this post by I6turbo:
Max707 (12-25-17),
mdjackson2 (12-24-17)
#45
If you're asking about my truck, the answer is, not any more. Without any modifications to the front mud flaps it would rub in both Normal and Low suspension modes when backing up and turning. Keep in mind that I have 25-mm spacers on the front and 30-mm on the rear, which is why the front rubs with the 305/50/20s.
The modifications to the front mud flaps (heating them and re-shaping them a little bit) to create more clearance are easy to make using a heat gun and some basic tools.
Here is where the contact occurs with un-modified mud flaps.
Here's the clearance after re-shaping the mud flap.
