LX - 3rd Gen (2008-2021) Posts related to the LX570 belong in this forum
Premium fuel really needed?
Old 01-26-18, 10:52 AM
  #166
Max707
Max707's Avatar
good info. I'm going to compromise and use regular every other fill up. Unless I have a heavy load or when temps are in the 90+ range or I'm going up mountains.
Old 01-26-18, 11:39 AM
  #167
andreasP
andreasP's Avatar
I had 2 bad experiences with regular gas on 2 turbo charged engines. In both cases, engine vibrations and hesitations were experienced. Since then, I started taking the recommendation for running premium seriously.
Old 01-26-18, 12:56 PM
  #168
2008GS
2008GS's Avatar
Originally Posted by REDHORSE
And here is the crux of the problem. All we have is anecdotal evidence, which is no evidence. Until I see results which are repeatable and repeated by others, conducted in a controlled environment, e.g. on a dyno, then I'll follow the information in the owners manual for whatever vehicle I'm driving.
I agree with this logic; everyone has theories. Why would Lexus recommend premium if it wasn't really needed? Are they in cahoots with the petroleum industry to sell higher priced fuel??? These are rhetorical questions because I will also use the manufacturers recommended grade fuel. The possibility of damaging the engine is too much of a risk for me.
Old 01-26-18, 01:20 PM
  #169
Max707
Max707's Avatar
We could be thinking about this backwards question could be why isn’t Land Cruiser and Toyota recommending 91 or requiring 91 octane in the Land Cruiser 5.7 is it because the vehicles it competes with burn 87 octane and Toyota knows that they can get a couple hundred thousand miles out of that engine even with damage long term from using to low of octane?
2008GS (01-26-18)
Old 01-26-18, 01:58 PM
  #170
I6turbo
I6turbo's Avatar
I would not run regular in a turbo engine, even a stock one. I keep at least 108 Motor Octane in my Supra, and often 112 -116. Then again, I typically run 30-35 PSI boost, so the effective compression ratio is very high, and there's a lot of thermal load on the engine under maximum output.
Old 01-26-18, 06:03 PM
  #171
REDHORSE
REDHORSE's Avatar
Sorry, still anecdotal. Where are the facts, supported by scientific testing. Just one example, "Don't think this will void your warranty." Someone show me a test done on a dyno about how much horsepower is or is not produced and what the fuel consumption is. Then I'll begin to believe the car companies are wrong. Need so life of the car testing also. The impact may be small. Then a statistical analysis of the data so others can repeat the experiments. Otherwise it is all just internet gossip.
Max707 (01-26-18)
Old 01-27-18, 08:59 AM
  #172
hankinid
hankinid's Avatar
Thumbs down
And even more "internet gossip" about regular gas destroying the engine. Any real time info on number of engines destroyed?
Old 01-27-18, 09:34 AM
  #173
Htony
Htony's Avatar
Perpetual argument. Just every one do whatever one wants with one's own vehicle. gasoline, oil, tires,etc., etc. Let's move on to some other
meaningful issues. For me always I fill with Shell premium to keep my car's engine clean having DI engine. No comment please.
Max707 (01-27-18)
Old 01-27-18, 07:32 PM
  #174
I6turbo
I6turbo's Avatar
To be clear, the Tundra/Land Cruiser/LX 570 engine is not a direct injection engine.
REDHORSE (01-28-18)
Old 02-01-18, 06:25 PM
  #175
Reggie1
Reggie1's Avatar
Based on availability at the times I need to re-fuel, I have run all grades of gasoline. I just do not subjectively feel any difference, even when towing my horses.
What objectively makes a difference is when running ethanol-free gasoline. With it I get 3+ miles more per gallon, based on the display screen. What is really nice is that increased MPG with ethanol-free for me translates into around 60 more miles of range.
About 300 miles range with ethanol bend vs 360 with ethanol-free..
Old 02-01-18, 10:27 PM
  #176
hankinid
hankinid's Avatar
The engine ECU adjusts for whatever gasoline you use. I run 91 octane Sinclair ethanol-free...definitely kinder to the rubber in the fuel system
I've towed a 3-horse Charmac with a 17 hand hunter and a 15 hand appendix. No issues whatsoever, but I definitely wife's 3/4 ton Dodge with Cummins.
Old 02-02-18, 05:04 AM
  #177
2008GS
2008GS's Avatar
I would expect more MPG with non Ethanol because ethanol provides less energy than pure fuel when burned.
Old 02-02-18, 01:30 PM
  #178
REDHORSE
REDHORSE's Avatar
The amount of heat energy in gasoline as compared to ethanol on a volume to volume bases is well documented and supported with facts. Having said that, my turbo charged Audi S8 does not achieve the 3mpg increase I see with my normally aspirated vehicles.
Old 08-07-19, 10:03 PM
  #179
Default I see zero reason LX needs premium fuel.
Sorry if this has been covered before, and I did do a search.
I'm looking for one of these and know the gas mileage is bad.
Its V8 is identical to the Tundra's 5.7 which calls for regular. There are zero differences; the compression ratios are identical.
I don't mind driving a gas guzzler but I really don't want to waste $12-15 bucks a tank on high octane fuel if I don't need to.
Does anyone here run regular? I wonder what the service techs at the dealer would tell me. Or the Toyota dealer.
Old 08-07-19, 11:09 PM
  #180
ClaytonW
ClaytonW's Avatar
No!!!! Not again!!! :-D
LOL, this post will be very popular!
BTW, not important at this moment, but I think that you are right and regular is O.K. for your LX.
glemmen1 (08-08-19)
Quick Reply: Premium fuel really needed?
