Remote Start won't work
2015 LX-570. A tag attached to my key fob says to quickly press LOCK twice & then to press & hold LOCK for 3 seconds.
I've tried it, & nothing happens. Any ideas? |
Do you have an Enform subscription active? I think it is required to use this function.
I don't have an Enform subscription. The Owner's Manual doesn't state that a subscription is required for Remote Start.
But - how do I subscribe? Bob |
Originally Posted by hazilim
(Post 9884873)
(Post 9885340)
But - how do I subscribe? Bob Good Luck as they are somewhat in turmoil due to a service update that has taken months. I am not positive that you have to have an Enform subscription but I do know that with the newer RX models, you have to. |
No Enform needed...
...as you have RES, not RES+. LX was one of the last (if not the last) model in the Lexus lineup to get RES+, which does require Enform and works via your phone.
Just guessing here, but try locking with remote, then unlock, then start regularly, then lock it, then try the "lock, lock, lock" remote-starting sequence again. |
Quickest way is to verify with the selling Lexus dealer to make sure that the remote feature was indeed installed and turned on.
I don't think you need ENFORM subscription to use remote start on the key FOB. Yes, if you want to use your smart phone to remote start.
(Post 9884873)
OEM remote and/or Enform, after market ones are much more robust with much more greater range. I installed one myself and I am laughing at the OEM one, LOL!
Just use your smart phone or fob to start the car. Better deal than paying subscripon fee for Enform. |
By the way:
If one can use an iPhone (thru Enform) to start the engine & access other info from the car, this suggests that the car itself is constantly online (full-time internet access). Are all of our LX-570's online full-time? Only the ones with Enform? Can Lexus (or the dealer) (or Sirius) access info from our cars (i.e. GPS data) whenever they please? Wouldn't a full-time internet connection drain the battery? Interesting! Anyone know about this? |
(Post 9886798)
By the way:
If one can use an iPhone (thru Enform) to start the engine & access other info from the car, this suggests that the car itself is constantly online (full-time internet access). Are all of our LX-570's online full-time? Only the ones with Enform? Can Lexus (or the dealer) (or Sirius) access info from our cars (i.e. GPS data) whenever they please? Wouldn't a full-time internet connection drain the battery? Interesting! Anyone know about this? The amount of power to maintain this connection would would be very small compared to the battery or batteries in the RX. My cell phone will run for a couple days on its tiny, in comparison, battery. |
From what I understand on newer Lexus' you need to be enrolled in the Enform services to even use the remote start. I don't know if the Enform Remote subscription is required for you to continue using the remote start from the key fob after the one year trial ends.
Originally Posted by ggebhardt
(Post 9886822)
Enform uses like a cell phone connection and is on all the time. And yes, I suspect that Enform knows way more than we think they do. It is quite likely they know even without an Enform subscription.
Originally Posted by Kira X
(Post 9894909)
They know a crazy amount of information especially if you have a current Service Connect and Enform Remote subscription. I recently started working at a Lexus dealership and it's crazy what kind of information is sent out. I'm personally very suspicious of all this stuff and you can choose to opt out, but I don't know if information is still collected.
Mine is a 2011, so it may be too old to compare. (Enform is not in my vehicle. I have an SOS button.)
I do have a small white tag on my keys with the same instructions for remote starting. I found that it takes longer than 3 seconds to initiate the remote start on the third press of the button. I hit lock, pause, lock, pause, and hold lock for 5 seconds. It doesn't always work on the first try, but I've always been successful. |
My guess is you have to have Enform Ap. I have the same tag on my fob (same year as well) and the car will remote start, but when i open the door, the car immediately dies.
Will ask the dealership when i go in for 30k mile check up next wk and revert. |
| All times are GMT -7. The time now is 04:34 AM. |
