LX - 3rd Gen (2008-2021) Posts related to the LX570 belong in this forum
HID Install
Old Dec 1, 2014 | 05:15 PM
SRL311U's Avatar
SRL311U
Default HID Install
All,
I just wanted to post up a quick note about HID installation. I will plan to post pictures in a follow up message. It was actually quite easy and I kept the AFS fully operational. I'm sure others have picked up on this, but the key is the 90 degree angle h11 bulbs as opposed to straight. This matches the stock set up. Also, I elected not to drill the center of the dust shields bit drilled at the very bottom, 90 degrees down to the ground. I lined the edge of the hole up with the edge of the plastic casting. This allowed me to leave a .33 inch extra length of wire on the headlight for AFS to work one rotated in place. The wire runs vertically instead of straight to the socket and mimics the OEM alignment. Others have likely realized this but I thought I would post it to pass on the knowledge.
Best,
srl311u
Old Dec 2, 2014 | 09:23 PM
UZ214's Avatar
UZ214
very interesting, let us know. It was pain to get the AFS working for me and end of the day i just disabled the system.
Originally Posted by SRL311U
All,
Best,
srl311u
Old Dec 5, 2014 | 03:08 PM
Booyah's Avatar
Booyah
You have any pictures of your install??
Old Dec 5, 2014 | 03:35 PM
caha14's Avatar
caha14
All,
Best,
srl311u
That's smart; thanks for sharing! I got mine to work, and it has been going strong for 4 years. I drilled on center, and that meant that I had to do more work to get the proper "service loop" in there. Should've done what you did.
In my case, passenger side worked right off the bat; driver's side took a lot of trial and error, for some reason. And of course, the space constraints on that particular side made life a bit difficult. Totally worth it, though!
Old Dec 11, 2014 | 03:01 AM
slowdiver's Avatar
slowdiver
All,
Best,
srl311u
Please keep us updated on this and post pics!
Old Jan 7, 2015 | 07:45 AM
SRL311U's Avatar
SRL311U
Default Pictures of Install
Old Jan 15, 2015 | 06:11 PM
crazy1323's Avatar
crazy1323
Where did you find the HID bulbs with a 90 degree?
Old Jan 19, 2015 | 01:12 PM
SRL311U's Avatar
SRL311U
I bought the Kensun 4300k from Amazon with a matching set for fog lights. I'm sure the vendors on here have much better quality but I wanted to test the install.
Old Apr 9, 2015 | 12:51 PM
slowdiver's Avatar
slowdiver
this is awesome!! thank you for posting!!
rdrunner
Sep 20, 2015 11:10 PM
silversx
Jun 2, 2008 02:24 PM
crubrexus
GX - 1st Gen (2003-2009)
16
Jan 15, 2006 11:46 AM
Samchu329
Lighting
Oct 4, 2003 12:18 AM
SC300TURBO
Jun 21, 2002 02:28 AM
