Service History Review
Hello All,
I am looking at a '10 LX570 with 200k miles on it, own owner. Interior looks very clean, frame looks rust free as well despite it being a florida vehicle. There's not a whole lot for the last 100k miles within the Lexus service portal. Was curious to get y'alls opinions on this transmission code from a few months back, as well as any concerns if the valley plate or starter have not been done per these records- is it safe to say those are for sure items to bank on needing to address in the near future? Thanks
3/24/2025 (199738 miles)REPAIR NUMBER:
REPORTED BY: Arrowhead Lexus
SERVICE: OTHERS
DESCRIPTION: ~|~CUSTOMER STATES TRAC OFF & VSC LIGHTS ARE ON, CHECK ENGINE LIGHT IS ON & 4LO FLASHING ~|~RETRIEVED CODES P0864 TRANS. SLIPPING, P2714 SOLENOID D STUCK OFF, P0761 SHIFT SOLENOID C PERFORMANCE STUCK OFF FOUND LSB-0008-13 AB60F TRANS CLUTCH/BRAKE DAMAGE FOR SAID CODES 3 ~|~PERFORMED RECALIBRATION PER LSB CLEARED CODES NO CODES RETURNED, IF CODES RETURN TRANSMISSION REPLACEMENT RECOMMENDED
SERVICE: TIRE LIGHT ON
DESCRIPTION: ~|~CUSTOMER STATES TIRE LIGHT ON - PLEASE ADVISE ~|~RETRIEVED CODE C2125 ID 5, FOUND SPARE TIRE TPMS SENSOR FAILED ~|~R&R ALL 5 TPMS SENSORS DUE TO AGE AND REPROGRAMMED
SERVICE: BATTERY/COIL SPK PLUG
DESCRIPTION: ~|~REPLACE BATTERY ~|~ ~|~REPLACED BATTERY
SERVICE: POWER STEERING HOSES
DESCRIPTION: ~|~REPLACE LEAKING PS HOSE ~|~FOUND P/S HOSE FROM REZ. TO PUMP LEAKING ~|~R&R P/S HOSE AND CLAMPS, CLEANED AREA AND TEST DROVE
SERVICE: NON WARRANTABLE OPERATION CODE
DESCRIPTION: ~|~REPLACE A/C AIR FILTER. ~|~ ~|~REPLACED A/C FILTER(S)
11/11/2019 (125146 miles)REPAIR NUMBER:
REPORTED BY: Lexus of Winter Park
SERVICE: ALIGN FOUR WHEELS
DESCRIPTION: ~|~ALIGN FOUR WHEELS WHEN REPLACING TIRES ~|~ ~|~ALIGN FOUR WHEELS,CUSTOMER DECLINED SERVICE -RECOMMENDED, NOT DONE-ALIGN FOUR WHEELS
SERVICE: MOUNT AND BALANCE TIRE (OLD & NEW DOT # REQUIRED)
DESCRIPTION: ~|~285/50/20 X2 GOODYEAR EAGLE GT2. LF TIRE AT 3/32'' AND 1/32'' ON EDGES. RR TIRE AT 4/32'' WITH 2/32'' ON EDGES. RF AND LR OVER 7/32'' ~|~ ~|~MOUNT AND BALANCE TIRE (OLD & NEW DOT # REQUIRED),CUSTOMER DECLINED SERVICE -RECOMMENDED, NOT DONE-MOUNT AND BALANCE TIRE (OLD & NEW DOT # REQUIRED)
SERVICE: FRONT BRAKE JOB, INCLS REFACING, W/O HARDWARE
DESCRIPTION: ~|~FRONT BRAKE JOB, INCLS REFACING, W/O HARDWARE DRIVERS SIDE INBOARD AT 2MM. PASS SIDE AT 3MM ~|~PADS IN RED STATUS ~|~FRONT BRAKE JOB, INCLS REFACING, W/O HARDWARE
SERVICE: REAR BRAKE JOB, INCLS REFACING, W/O HARDWARE
DESCRIPTION: ~|~REAR BRAKE JOB, INCLS REFACING, W/O HARDWARE SLIGHTLY BELOW 3MM ~|~PADS IN RED STATUS ~|~REAR BRAKE JOB, INCLS REFACING, W/O HARDWARE
SERVICE: DRAIN & FILL ENGINE COOLANT FROM RADIATOR & BLOCK
DESCRIPTION: ~|~PERFORM ENGINE COOLANT SERVICE IF REPLACING RADIATOR TO ENSURE ALL COOLANT IS FLUSHED FROM ENGINE BLOCK REMARKS: FLUID LEVEL LOW ~|~REPLACING RADIATOR AND THERMOSTAT ~|~DRAIN & FILL ENGINE COOLANT FROM RADIATOR & BLOCK
SERVICE: FLUSH POWER STEERING SYSTEM
DESCRIPTION: ~|~FLUSH POWER STEERING SYSTEM REMARKS: PREVENTATIVE MAINTENANCE ~|~MAINTENANCE. FLUID DARK/DISCOLORED ~|~FLUSH POWER STEERING SYSTEM
SERVICE: RADIATOR ASSY, R&R
DESCRIPTION: ~|~RADIATOR ASSY, R&R. SIGNIFICANT COOLANT LEAK FROM UPPER TANK TO CORE SEAM ~|~SEAM FAILURE ~|~RADIATOR ASSY, R&R
SERVICE: THERMOSTAT & GASKET, R&R
DESCRIPTION: ~|~THERMOSTAT & GASKET, R&R. RECOMMEND REPLACING WITH RADIATOR ~|~RECOMMEND REPLACING WITH RADIATOR ~|~THERMOSTAT & GASKET, R&R
SERVICE: FUEL INJECTORS, CLEAN
DESCRIPTION: ~|~FUEL INJECTORS, CLEAN. RECOMMEND TO IMPROVE/MAINTAIN IDLE QUALITY, PERFORMANCE AND FUEL EFFICIENCY ~|~MAINTENANCE ~|~FUEL INJECTORS, CLEAN
SERVICE: THROTTLE BODY CLEANING SERVICE
DESCRIPTION: ~|~THROTTLE BODY CLEANING SERVICE. RECOMMEND TO IMPROVE/MAINTAIN IDLE QUALITY, PERFORMANCE AND FUEL EFFICIENCY ~|~MAINTENANCE ~|~THROTTLE BODY CLEANING SERVICE
SERVICE: COMPLETED 120,000 MILES OR 144 MONTHS SERVICE - 2010 LX 570 (LEXUS
DESCRIPTION: ~|~120,000 MILES OR 144 MONTHS SERVICE - 2010 LX 570 (LEXUS FACTORY MENU) ~|~MAINTENANCE ~|~COMPLETED 120,000 MILES OR 144 MONTHS SERVICE - 2010 LX 570 (LEXUS
SERVICE: PERFORMED COMPLIMENTARY WASH AND VACUUM
DESCRIPTION: ~|~PERFORM WASH & VACUUM AFTER SERVICE ~|~ ~|~PERFORMED COMPLIMENTARY WASH AND VACUUM
SERVICE: JLL - REPLACE THE FRONT PASSENGER SEAT BELT
DESCRIPTION: ~|~SAFETY RECALL JLL - REMEDY NOTICE CERTAIN 2008 - 2019 MODEL YEAR LX 570 FRONT SEATBELT ~|~POSSIBLE AIRBAG DEACTIVATION ~|~JLL - REPLACE THE FRONT PASSENGER SEAT BELT
SERVICE: MILES OUT:125146
DESCRIPTION: ~|~TECHNICIAN MUST DOCUMENT MILES OUT WHEN SERVICE IS COMPLETED ~|~MILEAGE ~|~MILES OUT:125146
SERVICE: GUEST ACKNOWLEDGED ANY FIREARMS & PERSONAL PROPERTY REMOVED
DESCRIPTION: ~|~I ACKNOWLEDGED THAT I HAVE REMOVED FIREARMS AND/OR PERSONAL ITEMS FROM MY CAR & THAT THE DEALERSHIP IS NOT RESPONSIBLE FOR ANY ITEMS LEFT IN MY CAR. ~|~ PERSONAL PROPERTY REMOVED ~|~GUEST ACKNOWLEDGED ANY FIREARMS & PERSONAL PROPERTY REMOVED
SERVICE: TEXT MESSAGE COMMUNICATION AUTHORIZATION
DESCRIPTION: ~|~YOU AGREE THAT WE MAY CONTACT YOU REGARDING SERVICE UPDATES OR OFFERS VIA TEXT MESSAGES AT THE CELL PHONE NUMBER YOU HAVE PROVIDED. ~|~ COMMUNICATION AUTHORIZATION ~|~TEXT MESSAGE COMMUNICATION AUTHORIZATION
SERVICE: OTHERS
usedname
Oct 12, 2019 04:16 PM
Riz1
Feb 11, 2019 06:06 PM
