LX - 1st and 2nd Gen (1996-2007) Post here for topics related to the LX470 or LX450
Anything I should look for on my new to me 00 LX
Old 10-26-17, 07:25 AM
JohnLX26
JohnLX26's Avatar
Default Anything I should look for on my new to me 00 LX
Very excited to finally drive an LX / Land Cruiser, always wanted one of these and finally was able to find one.
Picked up an 00 LX470 w/ 120k miles from Toyota dealership. It came in as a trade in. Coming from an 09 Tacoma and so far so good. I have a few questions..
1. Unfortunately, I found out after my purchase that 2000 with the transmission failure year. Anything I can do to help keep an eye on this? I know this can get expensive..
2. I have the LX with Mark Levinson speaker and tape deck - Can I get a bluetooth audio unit with the stock speakers?
3. I looked at the service records on Lexus website. I see a 90k mile service.. it doesn't say anything about the timing belt.. does anyone know if it should state that? Trying to decide if I should just get it done for peace of mind.
Here's what I'm seeing:
REPORTED BY: Dolan Lexus
SERVICE: 90000 MILE SERVICE
DESCRIPTION: 90000 MILE SERVICE ~ ~CUSTOMER REQUESTS 90000 MILE SERVICE ~ ~SCHEDULED MAINTENANCE DUE TO TIME OR MILEAGE ~ ~90000 MILE SERVICE PERFORMED
SERVICE: RECOMMENDED MAINT
DESCRIPTION: RECOMMENDED MAINT ~ ~ ~ ~ ~ ~REPLACE BOTH FRONT CV BOOT CLAMPS
SERVICE: WINDSHIELD WIPERS
DESCRIPTION: WINDSHIELD WIPERS ~ ~REPLACE WIPER INSERTS ~ ~. . ~ ~REPLACED WIPER INSERTS
Then 30k miles later I see:
SERVICE: OIL CHANGE
DESCRIPTION: OIL CHANGE ~ ~REPLACE OIL & FILTER, CHECK BELTS, HOSES, FLUIDS & TIRE PRESSURE ~ ~SERVICE ~ ~PERFORMED SERVICE
4. Anything else I should look into? Few trips coming up so just wanna get this thing rollin smooth!!
Old 10-28-17, 07:20 PM
97-SC300
97-SC300's Avatar
https://forum.ih8mud.com/forums/100-series-cruisers.26/
For all your LX470 info and questions.
Old 10-30-17, 03:03 PM
hankinid
hankinid's Avatar
Wink
SERVICE: OIL CHANGE
1. I change the atf once a year or every 15K, whichever's first. Mobil 1 ATF does a good job. If the trans starts to act funky, get it to someone experienced with Toyota autos...probably not your local AAMCO.
2. Check the 100 series tech forum on ih8mud.com.
3. Afaik, the 90K service includes changing the timing belt. You can inspect the belt for newness by simply removing the drivers side cam sprocket cover...top of the engine forward.
4. If the AHC fluid is dark, change or have it changed per the book. I'd also consider R&R for the heater hose Ts...passenger side toward the firewall.
Congratulations and hth.
Old 10-30-17, 09:44 PM
YotaMD
Sponsor
YotaMD's Avatar
3. 90k should absolutely include the T-belt. For your own sense of security though, the actual rated life of those belts and associated components is roughly double the 90k interval for the 2UZ. If done at 90k you should never face any failures, but in all reality they're probably good to 180k. I just did a 90k service on my 100 series (255k total miles) and most my original bearings were noisy, but still perfectly functional at 255k. The belt looked perfect. Absolutely zero fraying or cracking. Assuming you don't have any stray leaks or odd problems, that engine is about as reliable as anything.
4. AHC fluid flushes are a good idea. Brake Fluid flushes are a good idea. There's a failure with the ABS pump that can be very expensive to fix. One way to keep it in good shape is to flush brake fluid regularly.
wombat55
GX - 1st Gen (2004-2009)
12-16-13 01:09 PM
vga1
04-15-10 05:53 PM
MJMeucci
01-14-09 09:52 PM
AgentWD-40
09-25-05 04:31 AM
Quick Reply: Anything I should look for on my new to me 00 LX
