LX - 1st and 2nd Gen (1996-2007) Post here for topics related to the LX470 or LX450
HID Foglight Retrofit
Old 09-11-17, 08:43 PM
Luke111
Luke111's Avatar
Default HID Foglight Retrofit
I had a set of Morimoto Matchbox projectors I was going to retrofit into my highbeam location but decided to put the Mini H1
in the high beam location so I decided to bake my fog lights, open them up and take a look.
it was really pretty straightforward I removed the OEM projector made a flat bracket that matched the factory attachment points using the plastic adjustment clip and mounted the matchbox projectors which fit perfect.
Attached Thumbnails HID Foglight Retrofit-img_2330.jpg   HID Foglight Retrofit-img_2331.jpg   HID Foglight Retrofit-img_2338.jpg   HID Foglight Retrofit-img_2383.jpg   HID Foglight Retrofit-img_2384.jpg
Old 09-12-17, 03:21 PM
hankinid
hankinid's Avatar
If you want to use your fog lights in actual fog, imo you'd be much better off going to a lower color temperature. White light tends to reflect right back into your face. Yellowish light does the deed in the fog. Mine are simply 45W hid lamps (3500K iirc) that throw a tremendous pattern just below the low beams. They also do a great job with enough of a horizontal spread to light up both sides of a 2-lane highway, including 3-4 feet each side of the pavement.
Steve
Old 09-12-17, 07:26 PM
Luke111
Luke111's Avatar
Steve
Thanks, I haven't decided what bulb I'll end up with.. I had previously done the HID retrofit in the fog lights using the existing projectors which gave me zero cut off.. The matchbox projectors are a true H ID which give me a clean cut off and I may take your advice .
not sure anything I put in thesre will make much of a difference...I'm just finishing up a quad set up using a Morimoto D2S
and the Mini H1
Attached Thumbnails HID Foglight Retrofit-img_2429.jpg   HID Foglight Retrofit-img_2434.jpg   HID Foglight Retrofit-img_2443.jpg   HID Foglight Retrofit-img_2437.jpg
Old 09-12-17, 10:40 PM
hankinid
hankinid's Avatar
High beams are sweet...
Old 09-13-17, 02:34 PM
Luke111
Luke111's Avatar
Smile
Those are all low beam shots.. Took your advice and ordered yellow HID bulbs for my fog lights
Old 09-19-17, 05:36 PM
Daddylee76
Daddylee76's Avatar
Awesome Job man! By the way for your low beams what size is it? The Morimoto D2S 2.5" or 3" and where did you get them from. Please let me know I'm interested in doing the same thing!
Old 09-20-17, 05:03 AM
Luke111
Luke111's Avatar
Default Projectors
I'm running D2S 4.0 and the Mini H1 in a quad setup. I designed a bracket for Morimoto projectors that replaces the OEM projector. I posted info about 8 threads down from this one
It would be easier to install the Mini H1 ....you have to open up the shroud to fit the D2S
There's more info on the links below
https://forum.ih8mud.com/threads/lx4...979351/page-16
www.lbbuiltwerks.com
Old 09-20-17, 08:05 AM
Kira X
美少女戦士セーラームーン
Kira X's Avatar
That is a sweet looking setup. I bet the visibility at night is a huge improvement over stock halogens.
Old 09-24-17, 06:18 PM
Daddylee76
Daddylee76's Avatar
Just ordered my Mini H1's from Morimotohid.com for $160.00 for a pair. Got it today but what's the 2 wires for? and my god the instructions for installation is written by a 2 year old. Tells nothing about how to install but just shows what the product is! I'm checking out your link and do I need the Bracket from that site? If so I can order that right? Thanks! I'm new to this retrofit game!
Old 09-24-17, 08:59 PM
Luke111
Luke111's Avatar
The two wires that are attached to a small black connector are the high beam trigger wires .. the connector plugs into the back of the projector.. You will need the bracket from my site. The Retrofit Source is a great source of information and watch some video's on You Tube... lots of great information. The first link below from TRS will detail the wiring and the link on Ih8mud has instruction on headlight removal and installing the bracket. You can also call me.. my number is on my site
Louis
https://www.theretrofitsource.com/me...1473952402.pdf
https://forum.ih8mud.com/threads/lx4...racket.979351/
Old 09-25-17, 10:31 AM
Daddylee76
Daddylee76's Avatar
Wow, thanks so much! So I went and ordered the bracket from your site. The PDF that you linked there is full and detailed. Once I get the bracket the only thing I got left is pulling the head light unit off, bake it, open it, retro fit it, then glue/seal back on. Or am I'm missing a step? I'm scrolling through your forum, and there's a lot of detailed information on it. Can you provide me with a short list of tools needed, any extra screws etc size? Thanks!
Old 09-26-17, 03:16 PM
Luke111
Luke111's Avatar
You'll need four small bolts and nuts to mount the projector on the bracket so a total of 8 and that's it.. do you have any questions give me a call my phone number is on my site
Caseyjones
07-22-14 03:40 PM
1nertia
01-07-09 10:57 PM
Jmai22
12
05-16-03 12:50 AM
Jmai22
GS - 1st Gen (1993-1997)
12-27-02 02:37 AM
Jmai22
10-24-02 10:40 PM
Quick Reply: HID Foglight Retrofit
