2002 lx470 - Torsion Bar Replacement/Upgrade
I just bought the title car with 170K miles on it. The suspension was converted to Bilsteins but I don't believe the torsion bar was replaced/upgraded which I've read should be done which will require you to then adjust to make the car level. Right now the car is drive is kinda loose and doesn't feel safe to the point where the traction control kicks in when on highway graded sloping turns which kinda freaks me out. The front end is visibly lower than the rear.
Question 1: Do I need to upgrade the torsion bar or just adjust the existing OEM? Oh and if upgrade is recommended, what should I upgrade to (where to purchase aka website)?
Question 2: Can anyone educate me on the traction control issue?
Overall I love the vehicle but it needs a couple of tweaks.
Thanks for taking the time to read my post and thank you even more for providing me with knowledge you may have regarding my situation.
Sleeoffroad.com sells a full line of suspension upgrades with a lot of tech info to help you educate yourself. I'd address the TC issue if it's still there once correct oem or heavier duty springs and torsion bars are installed, and height set per the book.
More in the 100 series forum on mud.
6SOARER
Suspension and Brakes
05-25-09 01:10 AM
