LX - 1st and 2nd Gen (1996-2007) Post here for topics related to the LX470 or LX450
Battery Light on and battery draining- help needed
Old 01-27-17, 01:35 PM
02lx47
02lx47's Avatar
Default Battery Light on and battery draining- help needed
Hello All,
I just purchased a 2002 LX470 about a month ago. When I first bought it the battery was dead so purchased a new battery and installed it. The issue is that when i installed the new interior LEDs and started driving around the battery light came back on and slowly drained the battery as i was driving, it died when i got home thankfully. The next day the car started right away and drove fine. Again as the day went on the battery light came back on and again the battery died. I have since removed all LEDs but did add HIDs. Again the same issue. I had the alternator checked at Tuffys and they said the alternator is fine. Anyone have any idea on what could be causing this issue? Again the only thing installed aftermarket now is the HIDs and fog lamps. Following is what i have done in terms of problem solving:
- new battery
- removed all LED lighting
- had alternator checked at Tuffys
- removed LED DRL
Please help! Thank you in advance!
Old 03-19-17, 10:11 AM
silverbul
silverbul's Avatar
If it's not your battery then check your terminals & make sure everything is grounded good. Just remember mostly everything is running of DC voltage & current flows from negative to positive. Most short circuits come from a bad ground connection
tickter
11-24-22 09:21 AM
lever2000
Performance & Maintenance
13
07-30-13 08:05 PM
gabzor
03-04-13 02:12 PM
masboy
03-04-12 06:37 AM
Donyo
29
04-04-11 11:54 AM
Quick Reply: Battery Light on and battery draining- help needed
