LX - 1st and 2nd Gen (1996-2007) Post here for topics related to the LX470 or LX450
annoying noise while shifting gear from "p" to "D"
Old 11-16-11, 01:38 AM
rajbertel
rajbertel's Avatar
Unhappy annoying noise while shifting gear from "p" to "D"
recently bought lx470 1999
i hv an issue regarding my trucks gear shifting when ever m trying to shift the gear position from "D" to "P" directly and from "D" to "R" / "R" to "D" (i hope u get what m trying to say)
i makes a annoying nudge noise like metal hit each other but the car stayes in its position fine n da car dose not jerk or nudges only the noise it makes, but if i shift the gear position from "N" to "D" or "D" to "N" its fine n smooth no noise at all
n while driving at low speed leaving the gas pedal idle n trying to hit the gas pedal n leave it idle again (like jerking the pedal) also makes same noise but it is quit low noise then it makes while da car is in still
my dealer said me to change the gear moldings n gear cushions etc stuffs n it cost me around 800$ but still no improvements n now they are asking me to change my front differential n axle n many other stuffs
, for which dey are asking me spend more then 4000$!!!!! m worried
is it a normal noise?? or something wrong with the truck ???or is the dealer just trying to eat all my savings
help me plzz
Old 11-18-11, 10:03 PM
B2001AS
B2001AS's Avatar
try to grease the shaft and between joints. Do not over grease it though.
Old 11-19-11, 01:17 AM
Hey Johnny
Hey Johnny's Avatar
https://www.clublexus.com/forums/lx4...ive-shaft.html
Old 12-28-11, 10:11 PM
mmwwh
mmwwh's Avatar
Hi rajbertel
Did you manage to fix the problem .. is it a serious damage?
Myself experienced the same situation
Old 12-28-11, 10:13 PM
mmwwh
mmwwh's Avatar
Hi rajbertel
Myself experienced the same situation like annoying noise while shifting gear from "P" to "D"
Hope to hear from you
Old 01-04-12, 04:42 AM
rajbertel
rajbertel's Avatar
Originally Posted by mmwwh
Hi rajbertel
it is da same with all 1998-2002 lx470 models nutthing wrong with the car
thx to my frnd who is a lexus expert
Old 05-19-15, 10:27 PM
easypeasy
easypeasy's Avatar
The jerk from P to D, or D to R, is likely the U joint. I am replacing mine shortly and will let you know.
Old 06-08-15, 05:08 PM
hankinid
hankinid's Avatar
As the FSM notes (just like any other greased spline slip joint), you grease it until you see grease exude a bit from the seal.
If you're not seeing that old grease come out and be replaced by new grease, you drop the shaft, pull the two pieces apart, clean, and re-grease. If still no grease, you need a new seal from your friendly local dealer.
hth
Steve
Old 07-20-15, 10:49 PM
Naruto
Naruto's Avatar
It can't be nothing wrong with the car. I've driving my 2002 LX470 for about 4 years. But only lately it developed exact same problem you described in this tread. It wasnt like that at least a decade. Only now it develops this annoying noise between D and R (vice versa)
We need to find out exactly what happened here.
Old 07-21-15, 09:28 AM
hankinid
hankinid's Avatar
The fact that "they all do that" doesn't necessarily mean that they all should do that.
Greasing the u-joints and splines on both drive shafts eliminate the problem.
Search the 100-series forum on mud for "driveshaft clunk" and go forward.
Steve
dyuanda
07-25-16 09:57 AM
lexusonly1
01-25-15 02:57 AM
mp33er
RX - 3rd Gen (2010-2015)
06-29-13 09:43 PM
FinLIFE
09-05-07 10:56 PM
Quick Reply: annoying noise while shifting gear from "p" to "D"
