Instrument panel & interior panel light problem
Hi
The lights that turn on inside when the headlamps are on won't turn on. The little wheel that is supposed to make them brighter does nothing. I checked the users manual and looked at the 2 instrument panel fuses (#15 & #30) and they seem ok
The car is 04 lx470
What do I check next.
Thanks
Roman
Thanks
Roman
The car is 04 lx470
Thanks
Roman
Thanks
Roman
Sorry to drag up this old thread....
I have the same issue.
instrument panel lights are off, all other lights are working fine. check Fuse #15, it's blown, replace fuse and gets blown right away. fuse #31 is still intact..
Then i noticed that when I turn the headlights on, the instrument cluster do not dim as they should, neither does the NAV screen. Seems like the dimmer is malfunctioning.
anyone has any idea if just the dimmer switch is the culprit. How do i test the dimmer? Please help. thanks.
cyclop123
10-02-12 12:41 PM
