Replacing Passenger Side Headlight Assembly and front clearance lamp
I managed to somehow break both the headlight assembly and the clearance lamp (side marker lamp) on my 2000 LX 470.
I cant seem to find a how to on replacing these two parts/pieces. Can anyone offer any direction on replacing these? Also, any good sources for the parts...they are OUTRAGEOUSLY expensive from lexus/Toyota.
For instructions, check the 100 series tech forum on mud... https://forum.ih8mud.com/forums/100-series-cruisers.26/ . Search for headlight replacement and you should find plenty of info. If you are not a member, joining up will reward you with tons of info on your truck.
For sellers, I'd just google "lx470" headlight and go from there. Later model plastic headlamps will fit, but you really need glass to match the driver's side. Afaik, the only source is gonna' be Lexus, or a salvage yard.
Good luck.
Stone chip in the glass headlight is the same as a stone chip in your windshield.
I searched for about 10 minutes...did not find any pictures. This may help... LX Headlight Removal
There is a small screw at the top of the side marker light.
You will see it once you open the hood.
To pop the side marker out you need to slide it straight forward.
You can pull from the side but that puts stress on the inner tab that slides and snaps into the headlight itself.
I have better luck sliding a clip removal tool, trim panel removal tool, or even a flat blade screw driver, sliding under the inner lip of the side marker lamp and prying against the headlight itself.
This puts the pressure closer to the tab and it should pop straight forward.
Sometimes you need to tilt the lamp a little to wiggle the upper tab out between the headlight and the fender.
Here's a picture.
Here's a picture.
A3OD
HS 250h Model (2010-2012)
04-20-19 02:26 PM
coupey
02-14-12 05:45 PM
