Cornering Lights
Don't know if it is anything like the RX assemblies, but I remember removing the inner fender well cover to get at the light assembly (turn the tires in or out to get at the screws/ they will be phillips head or 10mm). On our GX, I think you remove the plastic engine covers using a very small flat head screw driver to gain access to the light assemblies.
If it's the ones in the bumpers, you need to also take the liner out of the fender well and I think you can just twist 45 degrees and the light pops out. Good luck.
Open hood, remove the one philips screw. Now standing in front of the car (facing the windshield direction), you want to pull the entire corner lamp unit towards yourself (entire corner lamp slides forward). There is a plastic tab that holds the lamp in. Yes, it's one of those things that you think you broke when it suddenly comes loose after applying some force, but it'll be alright.
Rugster
May 22, 2014 09:24 PM
Can someone provide me information on how to replace the front right light bulb for the cornering light.
