LS500 annoying beeping in reverse
Old 03-08-18, 02:56 AM
Golfsnc
Golfsnc's Avatar
Default LS500 annoying beeping in reverse
Does anyone know how to disable the beeping sound when you put the car in reverse? So annoying.
Old 03-08-18, 07:39 AM
tfischer
tfischer's Avatar
Do they all do that, or just the h model? My recollection was that the reverse beep was added to some (or all) hybrids like the Prius because they often, or maybe always, use only batteries when in reverse and people kept running into kids and cats and stuff. I borrowed a friend's Prius for a few days, and it drove me nuts. On a Lexus full size sedan (or SUV), I would not have it - we are not driving dump trucks.
Old 03-08-18, 07:46 AM
comotiger
comotiger's Avatar
I am assuming you are the proud owner of an LS500. Congrats, and welcome to CL, and do post some pics.
This reverse beeping seems to be a very annoying feature. I looked thru the LS500 manual, especially the customization section, and could not find anything about turning off this feature. Your best bet is to take your vehicle back to the dealer and ask them.
Old 03-08-18, 09:09 AM
tfischer
tfischer's Avatar
That reminds me. I had an annoying and loud beep that would sound when closing the rear hatch on my RX. A kind forum member posted a very easy solution on the RX forum showing how to get to the beeper inside the back hatch and just unplug it. (A not-so-loud beep still sounded from under the dashboard, and I think nobody ever figured out how to disable this one, as I suspect it was connected to lots of different triggers.) The result made it much less annoying, and still no pets got squashed. If that sound at the back of the LS500 is from a single purpose speaker, you might be able to find the speaker or a wire leading to it.
Ask at the dealership, but Lexus dealers are very reluctant to alter the car with respect to items considered safety items - that's got litigation written all over it. However, an audio shop will usually be glad to help. Have them do this when you take the car there to get the hard wiring installed for your V1.
When I do my test drive, I'll see if this beep sounds on the non-hybrid version, and if the salesman won't agree to have it silenced, I'll suggest that maybe we should test drive a GS instead, as this is a deal breaker. I'll let you know what they say to that when $ is on the line.
Old 03-08-18, 09:44 AM
jzqj55
jzqj55's Avatar
Default Sounds like they had a brainstorming session. what can we do to irritate people?
Truck driver training
Old 03-08-18, 09:45 AM
jzqj55
jzqj55's Avatar
Default It gets weirder and weirder
What were they thinking?
Old 03-08-18, 02:29 PM
PCW
PCW's Avatar
I spoke to the lead Tech at my local Lexus dealer today and he told me that they can set it with their computer to one beep when you place the LS in reverse. Thereby eliminating the constant beeping.
Old 03-08-18, 03:40 PM
comotiger
comotiger's Avatar
If this is a dealer-customizable setting, then it will surely be adjustable using the Carista or similar apps and a OBD2 device.
Old 03-09-18, 12:48 AM
Golfsnc
Golfsnc's Avatar
Ahhhh. Great news. Thanks for the leg work
Old 03-09-18, 06:09 AM
tfischer
tfischer's Avatar
Yes! Infinity down - 1 beep to go.
Old 03-09-18, 07:18 PM
franklexus
franklexus's Avatar
Now that I think about it, the LS 460 is silent in reverse. I actually didn't notice the incessant beeping in the new LS until several forum members pointed it out. I can see why it will bug some people though.
Old 03-09-18, 10:06 PM
pgiinc
pgiinc's Avatar
The LS500h I drove made no noise I don't know how to turn it on
Old 03-11-18, 01:15 PM
Received 2,497 Likes on 1,800 Posts
Its because of the e-shifter on the LS500 vs the traditional shifter on the LS460. All Toyotas with an e-shifter beep the same way.
Old 03-11-18, 01:29 PM
tfischer
tfischer's Avatar
What's an e-shifter?
Old 03-11-18, 01:33 PM
e-shifter:
Reason for it is the shifter is just a switch that always goes back to center, so in theory its harder to realize you're in reverse. When we had our Prius it had a similar shifter and also beeped until we had the beeping deactivated.
Traditional shifter as found in the LS460:
The following 2 users liked this post by SW17LS:
franklexus (03-11-18), neilsarkar (03-22-18)
Quick Reply: LS500 annoying beeping in reverse
