Driving in High with Air Suspension
Old Oct 14, 2023 | 06:34 AM
hillsnow's Avatar
hillsnow
Default Driving in High with Air Suspension
Hi All,
The new '23LS we have has the Air Suspension. We have been keeping it in HI (high) when driving and adjusting the drive mode as needed. Does it matter if you keep it in High while driving vs. pushing the button to make it lower?
I am wondering what is recommended for longevity and comfort. Should it be kept Low while driving and High only when you need more ground clearance? Or does it not matter? Thanks!
Old Oct 14, 2023 | 07:42 AM
PGA71's Avatar
PGA71
Originally Posted by hillsnow
Hi All,
I often wonder this myself. Have been driving in high / comfort mode.
Have read somewhere when at certain speeds the height adjusts automatically by ECU.
Just remember if ever being towed or car jacked up to disable and turn off air suspension as per the manual.
Old Oct 14, 2023 | 09:53 AM
Higgie's Avatar
Higgie
Like the previous models LS 460 / 600h, the LS 500(h) lowers itself at high speed, if i remember correctly at about 75MPH. This is done for better handling and fuelconsumtion.
Driving in "high" is no problem and will not add more wear at your suspension. (Said my dealer) the car is build to do so.
jonasolof
Maintenance
May 19, 2022 12:40 PM
C0nn0r91
Aug 26, 2021 01:27 AM
OPSBD
Jan 9, 2010 09:18 AM
jpmotdyn
Apr 20, 2007 08:17 PM
