Pads
Old Feb 1, 2023 | 11:46 AM
allenhillv's Avatar
allenhillv
Default Pads
Rear pad?
should it be changed after a time and the rotors re-cross hatched 95,000…. 2011awd
Old Feb 1, 2023 | 12:01 PM
swfla's Avatar
swfla
In general members here recommend replacing rotors vs machining. Replace pads replace when worn.
Old Feb 1, 2023 | 12:12 PM
allenhillv's Avatar
allenhillv
sorry but the question was re cross hatched not re surfaced
plus pads crystallized after a time in use and the elements, just a general question among enthusiasts
Old Feb 1, 2023 | 01:54 PM
BB9's Avatar
BB9
Brake pads after years in service would definitely start loosing their qualities and replacing them is wise. As for the crosshatching that you referring to, it is a result of the machining the surface of the rotors in a very particular way. It helps to bed in new pads. If you want your rotors to have this crosshatching you need to do complete resurfacing per OEM standards. For starters you have to cut them anyway to ensure absolutely flat and parallel surfaces before final finishing on the proper machine can be done. Considering time and labor cost it would be cheaper to by new rotor.
Old Feb 1, 2023 | 05:42 PM
allenhillv's Avatar
allenhillv
Very well said ,,,Thank you
kiryu
IS F (2008-2014)
25
Oct 24, 2015 02:35 AM
RocketGuy3
Suspension and Brakes
20
Jul 17, 2008 05:16 PM
imran83
Jun 4, 2007 01:02 PM
