ClubLexus - Lexus Forum Discussion (https://www.clublexus.com/forums/)
-   LS - 4th Gen (2007-2017) (https://www.clublexus.com/forums/ls-4th-gen-2007-2017-178/)
-   -   car care nut's comments on LS460's reliability (https://www.clublexus.com/forums/ls-4th-gen-2007-2017/990964-car-care-nuts-comments-on-ls460s-reliability.html)
texas008 Aug 25, 2022 06:26 AM
Car care nut's video on fixing a LS430.
commenting: LS430 is more reliable, with parts more readily available and lower price.
"LS460 would fall apart with regular maintenance" I think this sentence is a bit of exaggeration.
__________________
texas008 Aug 25, 2022 06:27 AM
video link
Gerf Aug 25, 2022 06:55 AM
This guy is a leotard, but in all fairness some people listen to scotty kilmer as well.
Boykie Aug 25, 2022 07:01 AM
Tbh if he only worked on 06-09 - he's kinda right at this point in time.
swfla Aug 25, 2022 07:02 AM
He's a Toyota mechanic. Though the same parent company, Lexus is different. A few commonalities with Toyota. He's not a Lexus mechanic or expert.
sha4000 Aug 25, 2022 11:05 AM
I've watched a lot of his content and like most of it to find little pointers but most of his info does not cross over to Lexus.
Caflashbob Aug 25, 2022 11:37 AM
I wont tell my 200k solara that it’s supposed to fall apart.
Striker223 Aug 25, 2022 12:56 PM
I own both and 02 and a 07 and care for a near perfect low mile 06......they are the same. The 460 simply doesn't hide faults as well as a 430, you can have equally worn suspension but the 430 conceals the wear better since it doesn't handle or ride as well and the 460s multilink system is much more reliant on all links being intact.
The only real points of difference between the two are the brake system and engine, the brakes are hugely in favor of the 430 since it uses a normal system. The 460 however has a big edge in handling and braking response as well as the VIDM system being able to correct your line automatically mid corner without any input from you.
The engine in the 430 is also IMO a longer serving unit due to the belt and general format, it's far weaker output wise and also loses on MPG but it will outlast the 1UR. However even that said I vastly perfer the 1UR AA80E combo since it's far more reactive and just outright more powerful and didn't resist you driving aggressively vs a stock 430. Both are not that fast cars but the 460 is at least competent.....that said even at 252k my 430 can still hit 160 and beats it's factory 1/4 mile by .1
Interior on the 430 is more thought out and higher quality but a replaced 460 interior like mine is better than a nearly new 430 interior in all functional aspects.
I like to put it this way, a 430 is a better technical example where all the little things were thought about but the 460 is a better car.
