I recently swapped out the control arms tie rods and ball joints but there is a vibration around 20-30 mph. I had the tires balanced a month ago and just had a wheel alignment done. Can someone help me figure out what it could be
The vibration was a lot worse. But that was because of a loose inner tie rod before I changed it out. The current vibration is mild and cannot really be felt in the steering wheel
Were the wheels/tires rotated as well? Sometimes a wheel can be slightly out of balance and cause a mild vibration at certain speeds. It's possible a rotation may cure some small imbalance deviations.
I had the same issue. I was told when I got 5 new tires they checked the wheels for bent. I guess they missed this one. Swapped it with the spare fixed my long term issue.
