Can't register TPMS
Old May 17, 2022 | 06:35 AM
swfla's Avatar
swfla
glad that helped. You can change a lot of settings on your car with Carista. Explore it's capabilities.
Old May 26, 2022 | 10:12 PM
joedaddy1's Avatar
joedaddy1
question.. i will need to swap out the TPMS during my tire change (hopefully in June).
Hi. Can I program the new TPMS IDs using Carista before the tires are installed?
Example: Once new Denso TPMS, Carista, and tires (at-shop) are received, can I do the following?
1. Before driving to tire shop, program the new TPMS IDs using Carista.
2. Once at the shop, give the TPMS to the installer and let them know it's already programmed. (Costco or America's Tire).
3. Once tires installed, drive home.. whether the TPMS lights are on or not. Will they be on? Should I press the TPMS reset button in the driver footwell, so car sets the new PSI limits using installed tire pressure?
I just want to reduce the drama at the tire shop as much as I can.
Old May 26, 2022 | 11:14 PM
lexo98's Avatar
lexo98
Costco only installs sensors purchased from them. I would only buy sensors from the shop installing them. Too many issues can pop up and cost you a lot more in the long run.
Old Jun 5, 2022 | 01:14 AM
okitoor's Avatar
okitoor
I got the Carista and a set of new tpms sensors. Does it matter in what order i input them in the app? Ie Front left, FR, RearL, RR? Thanks
Old Jun 5, 2022 | 11:36 AM
lexo98's Avatar
lexo98
Start with the left front, right front, right rear, left rear
Old Jun 5, 2022 | 12:24 PM
swfla's Avatar
swfla
What about the spare tire?
Old Jun 5, 2022 | 12:26 PM
lexo98's Avatar
lexo98
spare goes last
mr29rose
Jul 24, 2021 04:40 AM
HKS350
Apr 26, 2017 07:23 PM
CJITTY
Aug 8, 2013 05:30 PM
MrFine
May 26, 2011 11:17 AM
