Weekend LS 460 work
Old Apr 2, 2022 | 04:01 PM
Cape600L's Avatar
Cape600L
Default Weekend LS 460 work
Decided to tackle my non working parking sensors today. Bumper off, diagnose, broken wire at connector on center sensor...damn it. Not enough to solder, so found one on a whole harness on eBay for cheap money. Now on to polishing the driving lights, etc etc. Also wanted to replace the "Swoosh" light bulb. Done. Bumper came off pretty easily. Just take your time with clips/fastners.
Looks Naked
Before.....
This kit was recommended on Youtube. Worked pretty well. I will stick to my tried and true method-1st step-400 wet sand, than to 1000, than to 2000. Then polish with 3m cutting compound and a green foam pad on my drill. Get it close with that than on to 3M fine polish with a blue foam pad. Happy to elaborate if anyone needs more info. Results speak for themselves!
After
Open hole is where the swoosh bulb goes.
Old Apr 2, 2022 | 04:16 PM
Anfanger's Avatar
Anfanger
Would you mind providing more details about polishing the headlights? My headlights are due to be reconditioned, so I am looking for any useful information. Are you going to put UV protection coating once the polishing is done?
Old Apr 2, 2022 | 04:55 PM
Cape600L's Avatar
Cape600L
Sure, will do my best. Here are links to what I used. The Sylvannia kit comes with a clear coat/UV protection. I did my headlights a few weeks ago and it is working well. Time will tell.
https://www.amazon.com/dp/B014SADBI0?psc=1&ref=ppx_yo2_dt_b_product_details https://www.amazon.com/dp/B014SADBI0?psc=1&ref=ppx_yo2_dt_b_product_details
https://www.amazon.com/dp/B00429NKWK?psc=1&ref=ppx_yo2_dt_b_product_details https://www.amazon.com/dp/B00429NKWK?psc=1&ref=ppx_yo2_dt_b_product_details
https://www.amazon.com/3M-05973-Rubbing-Compound-Quart/dp/B0002ZQ016/ref=sr_1_15?crid=RF3FHDMTKO94&keywords=3m+polishing+compound&qid=1648941577&sprefix=3m+polishing+compound%2Caps%2C85&sr=8-15 https://www.amazon.com/3M-05973-Rubbing-Compound-Quart/dp/B0002ZQ016/ref=sr_1_15?crid=RF3FHDMTKO94&keywords=3m+polishing+compound&qid=1648941577&sprefix=3m+polishing+compound%2Caps%2C85&sr=8-15
https://www.amazon.com/3M-Perfect-ItEX-Ultrafine-Machine-Polish/dp/B015S8S57S/ref=sr_1_13?crid=RF3FHDMTKO94&keywords=3m+polishing+compound&qid=1648941577&sprefix=3m+polishing+compound%2Caps%2C85&sr=8-13 https://www.amazon.com/3M-Perfect-ItEX-Ultrafine-Machine-Polish/dp/B015S8S57S/ref=sr_1_13?crid=RF3FHDMTKO94&keywords=3m+polishing+compound&qid=1648941577&sprefix=3m+polishing+compound%2Caps%2C85&sr=8-13
The key is that there is no quick and easy ways to do this. Take your time with the different grades of wet sanding. Than after the 2000 grit, start polishing with the more course compound and fast speed on drill. Don't push hard with drill, let compound do it's thing. Probably took me 15 min per driving light.
Old Apr 2, 2022 | 06:37 PM
It's a lot of work to do it right, I have a bunch of mobile detailers near me and one of them is a master at headlights. He only charges $80 a light and they are truly like new, warranty is two years no conditions apply.
Old Apr 2, 2022 | 06:38 PM
It's a lot of work to do it right, I have a bunch of mobile detailers near me and one of them is a master at headlights. He only charges $80 a light and they are truly like new, warranty is two years no conditions apply. Well worth it in my case to have him do it
Old Apr 2, 2022 | 11:24 PM
miket000's Avatar
miket000
I've been using this Blue magic stuff to clear up foggy / cloudy headlights for over 15 years on many different headlights. The best part is it only takes a few minutes on each headlight to clear them up. While it doesn't remove scratches or sand pitting it absolutely can clear a cloudy lens to near clear. For the time and effort involved it drastically improves the amount of light that passes out of a neglected headlight.
I've used it on my family's cars, to them the headlights look like new. Oddly enough the results last for many years. The trick I've discovered is to work a few square inches at a time switching to clean paper towels often. The liquid needs to be worked into the lens while rubbing with a paper towel. For those that don't have the time to do a full headlight restoration this stuff is great.
Amazon Amazon
Old Apr 3, 2022 | 08:34 AM
Boykie's Avatar
Boykie
...Guys. After polish you MUST apply UV-protector coat... Google 'toyota headlight restore kit'. NEVER leave clear plastic as-is after using cutting compounds. You'll get yellowing in a month or so...
Old Apr 3, 2022 | 10:50 AM
NotFasty's Avatar
NotFasty
Why are the front wheels off? Is that to gain better access to the clips and such around wheel well (to get the bumper off)?
Old Apr 3, 2022 | 11:11 AM
I figure that's a given....
Old Apr 3, 2022 | 11:19 AM
Cape600L's Avatar
Cape600L
Yes, you have to remove the screws for the front inner fender wheel well plastic to get access to the corner screws for bumper removal. I was also removing the headlights to access the swoosh bulb replacement.
Old Apr 5, 2022 | 08:30 AM
4litre's Avatar
4litre
Wow, you have been busy!
Old Apr 5, 2022 | 03:40 PM
Cape600L's Avatar
Cape600L
A labor of love! And to catch up on deferred maintenance
01LEXPL
38
May 19, 2012 09:32 AM
iKenn
North Texas Lexus Club
Aug 29, 2010 01:03 AM
uae
Feb 2, 2010 11:03 PM
carbongs
Feb 15, 2008 02:15 PM
skperformance
40
Oct 25, 2006 02:26 AM
