PCV valve or not
Old Dec 25, 2021 | 08:17 PM
Parrokeete's Avatar
Parrokeete
Default PCV valve or not
PCV valve on this 2007 LS 460? Where is it located and if not is there another unit performing this task and how do you replace it?
Old Dec 25, 2021 | 08:35 PM
Anfanger's Avatar
Anfanger
The PCV valve is located under the intake manifold. You have to remove the manifold in order to replace the valve.
Old Dec 25, 2021 | 09:40 PM
Parrokeete's Avatar
Parrokeete
Great, thanks. I was hoping to find a video on this one but looks like I might have to get a mechanic to do it.
Old Dec 26, 2021 | 05:19 AM
johnnyg66's Avatar
johnnyg66
You could but its not listed as a maintenance item. I thought about doing mine but changed mind due to its location. It in the valley of the engine.
I even bought one just in case.
Old Dec 26, 2021 | 06:17 AM
Anfanger's Avatar
Anfanger
If you remove the intake, make sure to replace the intake manifold gasket.
In terms of complexity, it is medium but time consuming. The biggest issues are the main harness and some connectors might have to be replaced if any get broken.
Old Dec 26, 2021 | 07:12 AM
Parrokeete's Avatar
Parrokeete
It may not be a maintenance item but sometimes they can need replacing, especially if a owner is not constantly using premium gasoline in their car because over time carbon can build up. I know most grades of gasoline have a treatment in them to help prevent it nowadays and maybe a gasoline treatment for this vehicle is not recommended.
Old Dec 26, 2021 | 07:15 AM
Parrokeete's Avatar
Parrokeete
Good information. Since I’m not experiencing a problem at the moment and I was just thinking about preventive maintenance I’ll just leave the PCV concern alone for now.
Old Dec 26, 2021 | 09:49 AM
And reseal the valley plate, if it's not leaking now it will at some point
Old Dec 26, 2021 | 02:15 PM
Anfanger's Avatar
Anfanger
Yes, it is a great idea considering there is a full access to the plate after the intake manifold removal.
Old Dec 26, 2021 | 04:27 PM
johnnyg66's Avatar
johnnyg66
True. I wonder what the Lexus engineers were thinking when they put it there. In some Toyota V8s it almost in the same spot but you can reach it with a socket extension.
Here is some other info on this PCV. I am assuming you already read it.
​​​​​​https://www.clublexus.com/forums/ls-...-location.html
Old Dec 26, 2021 | 06:16 PM
Cavedog's Avatar
Cavedog
Default What BS
The PCV is located to the left and a couple inches toward the firewall of the oil filler. I cleaned mine while cleaning the throttle plate. Pull the hose and put an open end wrench on it. Pull it and replace or clean with lacquer thinner, brake cleaner or carb cleaner. Shoot a little in and shack until the ball rattles, you are done put it back in.
Old Dec 26, 2021 | 07:28 PM
Parrokeete's Avatar
Parrokeete
Wow, that looks to be a lot more simple than taking the manifold off to do it. Thanks
Old Dec 27, 2021 | 05:52 AM
Boykie's Avatar
Boykie
Sadly it's bs
Old Dec 27, 2021 | 06:10 AM
swfla's Avatar
swfla
I've read multiple posts here about PCV valve and they all agree that disassembly is required. Cavedog is the only exception.
Old Dec 27, 2021 | 06:18 AM
Anfanger's Avatar
Anfanger
Originally Posted by Boykie
Sadly it's bs
I was wondering that too. What if the throttle body is removed, is there enough space to get to the PCV to replace it without removing the intake manifold? I never looked in such circumstances because I had a valley leak and the manifold had to come off anyway.
