0w-20 or 5w-20
LS460s from 2014+ have a 10K oil change interval in the manual.
Sorry to hijack this thread but I was curious, I recently bought a '13 LS460 RWD SWB used and found out that the previous owner (and first only) had all its servicing done at the dealership (every 5k KM consistently). Going through the servicing records, I couldn't help but notice that the engine oil they used is 5W40 (Shell Helix Ultra, which is pretty much Pennzoil Ultra/Platinum from what I have gathered).
Should I be alarmed about this? because from what I've read its only either 0W20 or 5W40.
Then again, I'm based in south-east asia so we don't have winter at all, mainly just summer and its blazing hot af (24 to 36 °C or 75.2 to 96.8 °F). Could this be a factor?
Any thoughts appreciated.
Being in NJ you should be fine with 0W 20, maybe if I was driving the car hard hard or taking it to the track racing it I would switch to a 0W 30. If I lived in a state with really hot Springs and Summers and drove the car hard/tracked it I would also probably go with a 0W 30 if I intend to keep it a long time and provide the max protection. The main reason automakers are switching to 20 weight oil from previously 30 weights is for the slightly better fuel economy it offers.
So you don't need to switch to a 5W oil as it won't have any better performance in hot weather nor do I think you need to switch to a 30 weight with a LS in NJ.
I would think a 40 weight oil would be too thick for a LS460 engine but you are in a very hot country so maybe it is different, I would think they would have just recommended a 0W or 5W 30 oil for a hotter climate instead of going all the way to a 40W. If Lexus recommends 40W oil in your region for a LS I would not be alarmed at all, just kind of surprised they recommend such a thick oil for a LS460 engine anywhere.
In any case, an interesting thing happened, Changed the oil (due 5km), used 5w30 amsoil xl + amsoil filter so it was a notch down from 5w40. Car ran weird after that service. A few misfirings and car ran noticably rougher, there were even some bobbles. Didn't wanna take the risk so I towed it back to the indie. They ran obd and it had some minor errors like not communicating etc. They cleared the codes and we drove it out for another test and the everything was fine. It was basically a so wtf happened moment and no issues...yet.
