Lexus (Transmission?) Noise when Accelerating
Old Jan 17, 2021 | 07:26 PM
alkmni's Avatar
alkmni
Default Lexus (Transmission?) Noise when Accelerating
2009 Lexus LS460
Tried searching online but to no avail. Currently have a problem where when accelerating to a higher speed ~40MPH+, there would be a loud whirring/humming noise in the engine.
Noise sounds like a motor fan spinning rapidly making the whirring sound. Most noticeable when driving on the highway, but on local streets (25mph), there seems to be no noise.
The higher the MPH and RPM, the louder/more present the noise is. Not sure if it may be transmission as it automatically shifts gear.
Any help appreciated, would like to self-diagnose before having to bring to mechanic, money a little bit tight right now.
Old Jan 18, 2021 | 04:44 AM
Anfanger's Avatar
Anfanger
Does the transmission have any issues shifting gears? Does the noise come from the engine or transmission? How many miles do you have on your car?
Old Jan 18, 2021 | 02:34 PM
alkmni's Avatar
alkmni
The transmission has no issues shifting gears. TBH i'm not quite sure where exactly the noise is coming from, but what I do notice is that when I put the car in Neutral and step on the gas, the humming noise still occurs. The car is around 145,000 miles.
Old Jan 18, 2021 | 03:38 PM
Anfanger's Avatar
Anfanger
What if you press accelerator in park to reach high RPM. Do you hear the noise?
Old Jan 18, 2021 | 06:26 PM
miket000's Avatar
miket000
The wheel bearings on these cars are more common to make noise then the transmission. If the noise is still present in neutral I would venture a guess that 1 or more of the wheel bearings are to blame. Often times at lower speeds they are silent even when worn out.
DJMinTN
Jan 17, 2021 09:10 PM
CAC1
RX - 3rd Gen (2010-2015)
Jan 12, 2017 11:51 AM
vimal01997
Apr 29, 2015 08:08 PM
subsurf
Oct 6, 2014 07:36 PM
