Error Code P1343 LS 460L Help
Old Sep 29, 2020 | 07:12 PM
VelvetJonz's Avatar
VelvetJonz
Default Error Code P1343 LS 460L Help
I have a 2011 LS 460L and currently I am getting error code P1343 Camshaft Position Sensor A High Input MRE. To backtrack a little bit I was getting P0345 Camshaft Position Sensor Bank 2. Took it to a certified mechanic had it replaced and now I’m getting the P1343. Has anyone had this problem? What was the remedy in fixing it? Does anyone know where the Camshaft Sensor is located for bank 1? Does anyone have a pic or diagram of the location?
Old Sep 30, 2020 | 03:58 AM
lwphat66's Avatar
lwphat66
This diagram may be of help. Timing drive (UR series). 1 - VVT-iE motor, 2 - VVT-i control solenoid, 3 - crankshaft position sensor, 4 - camshaft position sensor (intake), 5 - camshaft position sensor (exhaust), 6 - water temperature sensor, 7 - camshaft position sensor.
Old Sep 30, 2020 | 08:03 AM
VelvetJonz's Avatar
VelvetJonz
So between 4,5, & 7 which one is bank 1?
Old Sep 30, 2020 | 08:14 AM
Anfanger's Avatar
Anfanger
Bank 1 is usually on the right when you face the vehicle.
Unicorn300
Sep 29, 2020 07:02 PM
DonTripp
Aug 9, 2020 05:59 AM
jcooper2
Feb 22, 2012 12:26 PM
saelee39
Jan 24, 2010 09:33 PM
