2014 LS 460 AWD... slight vibration on deceleration? cause?
Old Jun 26, 2022 | 08:39 PM
  #31
jonnyls87's Avatar
jonnyls87
2nd gear
Originally Posted by Tec80
Try bumping into neutral during the vibration. If it stops vibrating, replace the rear transmission mount and/or shim the forward differential cushions up using the selective washers available as service parts.
Hey Tec80,
not real familiar with working on the LS… I’ve got a 14 AWD L with similar symptoms. Is the rear trans mount easy to do with Jack stands in a drive?
can the shim be added without removing the mount?
Old Jun 27, 2022 | 03:01 AM
  #32
Anfanger's Avatar
Anfanger
AWD has 3 transmission mounts, the exhaust in the way of 2 side mounts. However, it is possible to replace both without removing the exhaust by lowering and rising the transmission. At least, I was able to.
Old Jun 27, 2022 | 05:05 AM
  #33
jonnyls87's Avatar
jonnyls87
2nd gear
thanks for the reply.
I have the same symptoms described above…slight vibration with deceleration but goes away when I pop it in neutral.
if it’s something I can tackle myself, I’m willing to give it a go. If it’s a pain in the drive, I will likely bring it in.
Old Jun 27, 2022 | 01:47 PM
  #34
Anfanger's Avatar
Anfanger
I am not sure what your skills are. I am just a DIY person, it did take a little longer than I thought it would.
Old Jul 19, 2022 | 12:38 PM
  #35
CMS062407's Avatar
CMS062407
Replace the rear transmission mount.
oops, I meant to quote you so you can see I replied
to you . Here is my comment!
Is that what you ended up doing with yours? I see your thread in which you stated they replaced both axles and the CV support bearing. Did that end up not actually being the fix for your similar issue?
I also read you talking about the drive shaft alignment being out of wack and that there are some different size spacers that could be installed.
2012LS460
Jun 15, 2022 08:04 PM
Tw1208
May 27, 2020 04:03 AM
Sailor54
Sep 30, 2018 09:57 AM
mbarron37
Aug 6, 2014 06:06 PM
joeyb
Jun 24, 2013 12:27 PM
