P0174 Code Need Help
****Update Fixed!****
I keep receiving this code with CEL and VSC. Along with a pungent rotten egg smell and a rough idle. The smell and rough idle ONLY happens when the code pops up or about to pop up. When the code goes away the car is silky smooth and the exhaust odorless.
I have cleaned both MAF and swapped sides to see if the code would change to P0171 but it didn't. Code was still P0174 after it reoccured so I'm guessing its not the MAF.
Help Please!
____________________________________
Im bored so I figured I would update this to help someone out if they have the same problem.
Changing my valve cover gasket and O2 sensor did remedy this issue. Here I am a year later and the check engine light never returned.
Car had a slight vibration at idle too because of the bad signals the old O2 was sending to the computer; all of this subsided!
Help Please!
Check the 02 sensors, valve cover gasket, and high pressure fuel pump. Make sure it's not leaking gas into the o2 sensors.
Help Please!
Help Please!
