Water drops under driver side
Old Jun 30, 2019 | 07:34 AM
Thegamemhb's Avatar
Thegamemhb
Default Water drops under driver side
How are you guys .. so two days back i was on a long drive after two hours of continous ac and highway drive i started feeling few drops of water dripping on my feet anyone with any idea what it can mean is it a clogged ac drain ?
Ls460 2008
Outside Temperature was around 100f
Old Jun 30, 2019 | 12:15 PM
Thegamemhb's Avatar
Thegamemhb
I was reading about the ac drain any idea where is ac drain located ?
Old Jun 30, 2019 | 02:23 PM
jkittlesen's Avatar
jkittlesen
Right hand or left hand drive ?
Verify coolant or clear water out of condensate drain(clear water).
Old Jun 30, 2019 | 02:45 PM
Thegamemhb's Avatar
Thegamemhb
Left hand drive american specs
I dint get the secpnd part of your message
If it means the drops that were dripping under the steering side i dint notice the color
Old Jun 30, 2019 | 03:08 PM
jkittlesen's Avatar
jkittlesen
Check your passenger side carpet is it wet?
When the a/c is operating do you notice the a/c draining outside the car on the ground?
A/C drain line clogged car, Youtube this to get a general idea!
Old Jun 30, 2019 | 03:11 PM
Thegamemhb's Avatar
Thegamemhb
Yes i did notice water dripping outside the car today
Passenger side was dry
I will search now on YouTube
I read on some forum that you can try using air pressure if you can locate the drain pipe any suggestions on it ?
Old Jun 30, 2019 | 03:20 PM
jkittlesen's Avatar
jkittlesen
Look at youtube it will answer your ?
Old Jun 30, 2019 | 03:24 PM
Thegamemhb's Avatar
Thegamemhb
Watching the videos thank you for it ...
Solution is to use air pressure but any idea about the location of the drain as every car is different i will try looking for it in the morning and will notice if the water is leaking on the passenger side aswell ..
Once again thank ypu for your reply
Old Jun 30, 2019 | 03:26 PM
jkittlesen's Avatar
jkittlesen
You will have to get under the car passenger side, look for water stream(A/C on) and you will find the drain.
Get flashlight and open the hood to get some light in the engine bay to see.
Old Jun 30, 2019 | 03:29 PM
Thegamemhb's Avatar
Thegamemhb
Thank you so much i will look for it and update tommorow
Old Jun 30, 2019 | 03:31 PM
jkittlesen's Avatar
jkittlesen
Good luck sir!
tarheel49
Jul 16, 2019 09:42 AM
shugo88
Jun 6, 2019 04:46 AM
dbl047
Aug 24, 2011 02:59 PM
SC3coupe
Sep 12, 2007 08:22 AM
Whitmanpc1
Jul 1, 2001 05:06 PM
